MCEBuddy FAQ - Install, Uninstall and Start Up Issues
Sometimes MCEBuddy will run into various issues while installing, uninstalling or starting the application. Listed below are some of the common error messages and resolution steps. Please make sure you DO NOT SKIP any step and ORDER is very important.
  1. ALWAYS perform a complete uninstall of the previous version of MCEBuddy before installing a new version.
  2. ALWAYS delete the previous installation of MCEBuddy (by default in the C:\Program Files\MCEBuddy2x) before installing a new version of MCEBuddy.
  3. MCEBuddy automatically saves and restores the key configuration files from the installation config directory (history, mcebuddy.conf and profiles.conf) while uninstalling/reinstalling. While reinstalling it restores a backup of the old configuration files (mcebuddy.conf.old and profiles.conf.old) for your reference. PLEASE DO NOT REPLACE THE NEW CONFIGURATION FILES WITH THE OLD FILES AS PARAMETERS IN THE NEW FILES ARE ADDED/UPDATED WITH EACH RELEASE.
TABLE OF CONTENTS
How do I do a of MCEBuddy?
  1. Uninstall MCEBuddy from the Start Menu or the Uninstall Programs Shortcut (Control Panel)
  2. Delete the MCEBuddy Service:
    • Find cmd.exe or command.exe in the Start Menu -> Accessories.
    • RIGHT CLICK on it and select Run as Administrator.
    • In the command prompt type sc stop MCEBuddy2x and press Enter. This should stop the MCEBuddy service.
    • Now type sc delete MCEBuddy2x and press Enter. This should delete the MCEBuddy service. Do not worry if it gives an error saying service does not exist.
NOTE: If you do not run as an administrator then the service deletion will fail and MCEBuddy will not install.
  1. Delete the installation directory (usually C:\Program Files\MCEBuddy2x) - you will have to check where MCEBuddy was installed
  2. Delete the backup configuration files stored by MCEBuddy. Open the folder %HOMEPATH% (this is a windows variable, just type that into your Run prompt or Windows Explorer). Delete the following 3 files if found, mcebuddy.conf, profiles.conf and history
  3. Reboot the computer
If you’re facing the following error while trying to uninstall/install MCEBuddy, “The feature you are trying to use is on a network resource that is unavailable”, this is due to a Windows Installer corruption and you need to follow the instructions here:
https://thegeekpage.com/the-feature-you-are-trying-to-use-in-on-a-network-resource-that-is-unavailable-in-windows-10-fix/
The uninstaller is not working. How do I do a force uninstall MCEBuddy?
Follow the below steps to force remove MCEBuddy if the Windows installer is corrupted/unable to uninstall it. CAUTION: ADVANCED EXPERIENCED REQUIRED OR YOU MAY END UP MAKING WINDOWS UNUSABLE
  1. Stop the MCEBuddy2x service from the windows service manager (run services.msc) and close the MCEBuddy GUI/Application
  2. Delete the MCEBuddy2x folder from the Program Files folder
  3. Start an Administrative command prompt (right click on cmd.exe or command.exe and select Run as Administrator), type sc delete mcebuddy
  4. ONLY DO THIS STEP IF YOU ARE FAMILIAR ON HOW TO OPERATE THE REGISTRY. IT CAN STOP YOUR COMPUTER FROM OPERATING IF YOU MAKE ANY MISTAKES. Open the Registry, navigate to the following registry keys, search for and delete entries or keys as appropriate with MCEBuddy2x in them
    HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Assemblies\ (delete keys)
    HKEY_LOCAL_MACHINE\SOFTWARE\Installer\Assemblies\ (delete keys)
    HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\ (delete key)
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\Folders (delete entries)
  5. Reboot the computer
MCEBuddy Engine does not start . Windows Event Viewer contains the following error –> This access control list is not in canonical form and therefore cannot be modified.
CAUSE
MCEBuddy wasn’t uninstalled properly and left the directory in a corrupted state.
RESOLUTION
  2. Delete the previous installation of MCEBuddy (by default in the C:\Program Files\MCEBuddy2x ) before installing a new version of MCEBuddy.
  3. Reinstall MCEBuddy
  4. If that does not work, then follow the procedures for a clean install
MCEBuddy Engine does not start . Windows Event Viewer has the following Error System.ServiceModel.AddressAlreadyInUseException: There is already a listener on IP endpoint 0.0.0.0:23332
CAUSE
MCEBuddy wasn’t uninstalled properly and did not remove the service properly.
RESOLUTION
  1. Uninstall and reinstall MCEBuddy
  2. If that does not work, then follow the procedures for a clean install
Service name already exists
CAUSE
Previous uninstallation was not clean and the MCEBuddy service was left behind so the new installation cannot complete until the old service is removed.
RESOLUTION
  1. Delete the MCEBuddy Service:
    Don’t worry if it gives an error saying service does not exist.
  1. Delete the entire installation directory (by default in the C:\Program Files\MCEBuddy2x).
  2. Now try to install the new version of MCEBuddy
While UnInstalling it gives an error, Service Does Not Exist
CAUSE
Some antivirus programs such as Norton mistakenly identify MCEBuddy as an unwanted service and delete it. This causes the uninstallation to fail.
RESOLUTION
  1. Goto Control Panel -> Uninstall a program
  2. Select MCEBuddy and click Change and Select Repair
  3. After the Repair is complete you can now Uninstall MCEBuddy
When installing I get an error message “The configuration data for this product is corrupt. Contact your support personnel”
CAUSE
When the previous version was uninstalled the Windows Installer left corrupted data in the registry
RESOLUTION
  1. NOTE: THIS ASSUMES YOU KNOW HOW TO USE REGEDIT TO EDIT THE REGISTRY. THIS IS AN ADVANCED CONCEPT AND RENDER YOUR OS IMPAIRED IF USED INCORRECTLY
  2. Open the registry editor by typing in regedit.exe in the Run from the Start Menu
  3. Navigate to the registry key -> HKEY_LOCAL_MACHINE\Software\Classes\Installer\Products\
  4. Find and DELETE any/all of the following keys, depending upon which version(s) of MCEBuddy you had installed/tried installing earlier:
    • MCEBuddy 32bit Key -> 24C2BB9D-EEDB-449D-AD22-24CFFD29B43E
    • MCEBuddy 64bit Key -> 0D3796AA-D867-4278-AEBC-3616AD1F7C3A
    • MCEBuddy Remote Client Key -> 52306C3E-A88E-4A36-8A31-164BA14B81C6
  5. Close the registry editor, install MCEBuddy now
I have a port conflict on my local machine (port is already in use)
CAUSE
Another program is using the port used by MCEBuddy. By default MCEBuddy uses port 23332 for communication.
RESOLUTION
  1. Stop the MCEBuddy engine
  2. Open MCEBuddy.conf
  3. In the section [Engine], change the LocalServerPort to another port number which is not used by any other application (choose from 1 to 65534) (try a random port number greater than 1024 if your don’t know which ports are used). If you don’t find it then add the following line in the [Engine] section and save the file.
    LocalServerPort=23332
  4. Reboot the computer OR Restart the MCEBuddy service (Control Panel -> Services -> MCEBuddy 2x -> Right click and select Restart)
An exception occurred in the OnInstallAfter event handler of System.ServiceProcess.ServiceInstaller. –> This access conrol list is not in canonical form and therefore cannot be modified
CAUSE
MCEBuddy tries to create the temp and log directories after installation. Sometime there is a security conflict with the previous version of MCEBuddy and the new version cannot create/delete the directories.
RESOLUTION
MCEBuddy service failed to start
MCEBuddy service is unavailable
Windows 10 and ryzen
Can't install 2.5.4 release after uninstalling prior beta
The MCEBuddy service is unavailable. Please start from windows control panel or check engine connection
New install - video converting but no commercials are being removed
MCEBuddy engine not starting
How to change port number?
Error 1001. The specified service already exists
Help Service is unavailable
Engine Core Problem
Service not starting after reinstall
Remux Failed - PlayOn mp4 to HEVC mkv
Installation failure
Welcome to MCEBuddy - README BEFORE POSTING
Upgrading from 2.5.x to 2.6.x
ERROR> --> Unable to open INI file. Error : SharpConfig.ParserException: Line 7277: closing bracket missing
The GUI says the service unavailable but Windows shows it running
Upgrading from Older Versions of MCEBuddy
Purchase and upgrade
The mcebuddy service is unavailable
Drive ran low on space all Settings, Monitor locations, Conversion tasks, History, etc are gone
Unable to search folders. Isnt selecting files to be converted
RTF release notes no longer viewable in Windows11 (winword was removed)
Profiles missing after upgrade
Previouse Insatll Config
Settings button not working - UI Hanging
No response... 300 seconds, process likely hung - killing it
Failed conversions
Install problem with version 2.7.1
Conversions are crashing and stopping
Will not remove commercials, even after clean install
MCEBuddy FAQ - Common Issues and Errors
Mcebuddy failed to remove some commercials and removed some of the movie
App Crashing and Can't Uninstall!
Unable to uninstall MCEBuddy
Unable to get old 2.5.8 profiles removed (keeps on populating new ver)
Help Error 1001
Stopped working-can no longer uninstall
Documentation update for uninstalling
2 posts were split to a new topic: Unable to reinstall, windows installer unresponsive
