MCEBuddy can automatically convert image based subtitles (e.g. DVB) into a text subtitle (SRT) using OCR (Optical Character Recognition). However this feature requires additional files to be downloaded. This is because OCR processing requires very large data files (~1 GB in size) which cannot be bundled within the MCEBuddy setup file.
MCEBuddy Version 2.6.2 and newer
During installation the option to automatically download and install the required OCR add-on files is enabled by default. You can disable it if do not want the OCR add-on files downloaded and installed automatically.
If you did not select the automatic installation during setup, you can at anytime trigger an install/re-install of the OCR add-on files by clicking on the Install OCR add-on
link in the Conversion task page as shown below:
InstallOCR add-on
in grey means that the add-on files have been installed. Click on the text to redownload and reinstall them (~500MB download)
Install OCR add-on
in red means that the add-on files have not yet been installed. Click on the text to download & install them (~500MB download)
Make sure that Save subtitles
or Embed subtitles
options are enabled in the Conversion task → Advanced settings to extract and process subtitles using OCR.
MCEBuddy Versions 2.4.7 to 2.6.1
You will need to manually download and install the OCR files as described below.
Follow the below procedure to enable OCR and image to text subtitle conversion to extract DVB and other image based subtitles from recordings.
- Download the OCR files from https://github.com/tesseract-ocr/tessdata/archive/3.04.00.zip
- Extract the contents of the zip file (
tessdata-3.04.00.zip
). It should create a folder calledtessdata-3.04.00
inside which will be 100+ traineddata files. Make sure there are no sub-folders. It should look liketessdata-3.04.00\<100+ traineddata files>
- Move the folder
tessdata-3.04.00
to inside the ccextractor directory where MCEBuddy is installed: <MCEBuddy installation directory>\ccextractor\
e.g. Movetessdata-3.04.00
to insideC:\Program Files\MCEBuddy2x\ccextractor\
- Rename the
tessdata-3.04.00
directory totessdata
. Important: Do not miss this step or OCR wont’ workSo your final setup should look like: <MCEBuddy installation directory>\ccextractor\tessdata\<100+ traineddata files>
e.g.C:\Program Files\MCEBuddy2x\ccextractor\tessdata\<100+ traineddata files>
Make sure you’ve enabled the Extract subtitles and closed captions
option in your Conversion Task advanced settings and you’re all set! It will extract and convert image based subtitles into a text SRT file. Enjoy!
Versions older than 2.4.7 do not support OCR
