I have been struggling with GPU encoding for a few weeks.
I am running Windows 10, using a GTX 1050.
I found this thread that says to use driver version 376.51. When I use that driver, the GPU encoding does not work at all.
I have tried different versions of the driver, currently I am using the CUDA driver from Cuda toolkit version 11.4.0_471. Not sure how to find what the driver version is.
Here is where things get weird. The GPU encoding WORKS, but the performance is drastically different between different encodings.
I am converting videos recorded from an HDHomerun.
A 1 hour recording takes about 16 minutes. During that time the GPU usage will be about 60%. I think this is great performance.
Other times a 1 hour recording from the same source, with the same MCEBuddy profile/settings can take 1.5 - 2 hours. During that time the GPU usage will be about 7% - 9%.
The GPU is doing something, just vastly different in terms of performance.
Attached is a log, converting a 1 hour show in 16 minutes.
fast.txt (14.2 KB)
Here is the conversion log of another 1 hour show, it takes 90 minutes. The logs show it is using GPU encoding, so what causes 1 video work convert in 16 minutes and another video almost 6 times a long?
slow.txt (14.0 KB)
I have been unable to figure out what causes the performance difference. I have tried rebooting between encodings, restarting MCEBuddy - nothing is consistent.
