E-mail settings MCEBUDDY
does anyone know how to set up e-mail
POP is for incoming mail. SMTP is outgoing.
SMTP Server should be:
Type “smtp.mail.yahoo.com” into the text field for the outgoing mail, or SMTP, server. Use “smtp.bizmail.yahoo.com” if you have a Yahoo Business Email account. Port should be 465.
this is what I get
Try using port 587 instead of 465
still don’t work with 587 iam run the 2.4.8 PREMIUM
Add @yahoo.com to your username. It is port 465.
what iam do wrong ?
I corrected my message. mine failed too. I accidentally hit cancel and ran the test. It used my none yahoo settings.
oh I see I hope they get this fix
Yahoo says
Outgoing Mail (SMTP) Server
Server - smtp.mail.yahoo.com
Port - 465 or 587
Requires SSL - Yes
Requires TLS - Yes (if available)
Requires authentication - Yes
Your login info
Email address - Your full email address (name@domain.com.)
Password - Your account’s password.
Then at has to do something with your firewall I presume because I did test this one and it definitely worked.
Is there a space between web and the dash? Shouldn’t be.
so what can do get this fix ?
Check/disable your firewall, it could be on your computer or your router. Or your ISP could be blocking the ports. Many ISP’s don’t allow SMTP ports. You will contact them in that case to open the ports.
