“Service unavailable…” I KNOW it’s my port. Yet when I go into the .config and [engine] the option isn’t there like it says in the toubleshooting. Any help would be appreciated.
If it’s not there then it means MCEBuddy never initialized after the install and it used the default port. If you think it’s because the port is in conflict then add the line:
LocalServerPort=23332
Change the port to whatever custom port you want, save the file and restart the service or reboot the computer.
