Hi,
I have been running v2.5.7 beta for the past year with no issues. At the end of the year I upgraded mcebuddy to version 2.5.8.
For movies, mcebuddy should rename them and then move them in to a file folder, and delete the original. Since the upgrade, I have recorded two movies which are being renamed and moved to the newly created folder. However, the original recording is not being deleted as it was previously.
Recorded TV is handled the same way and is working fine.
I attached the log for the two movies. Can you provide any insight on how I can correct this?
I can’t see the monitor location settings in these logs (that’s in MCEBuddy.log) but check your monitor location to see if you’ve enabled the option to delete the original file.
One other thing, previously I indicated this was only happening with movies but that is not accurate.
Now that regular TV is coming back, it is happening to Recorded TV.
