What is the best way for MCEbuddy to quickly check a TS file for timestamp errors and correct them?
Do I have to do a full conversion, or will an Unprocessed setting be sufficient?
I do not do commercial skipping
I did see a ‘Skip remuxing files’ option in the expert settings. Does this mean it will remux unprocessed TS files if not checked?
Unprocessed copies the video and audio as is (unprocessed). A full conversion is required to scan and fix defects (if possible).
Remuxing changes the container format and doesn’t alter the video. It’s done for compatibility purposes and as a safety so that the original video is left unaltered.
