Retain Logs on upgrade
Request Type:
Feature
2.4.9 Beta
Windows 10 64-bit
Logs are removed during upgrade process … but there would be value in retaining them.
Steps to replicate the bug:
Logs get removed during the uninstall (which I suppose makes sense), but it is required to uninstall in order to upgrade. It would be nice to retain the logfiles after an upgrade.
Perhaps they belong in a USER area rather than a PROGRAM area so that they can be separated.
When uninstalling the installer cleans up everything. MCEBuddy backs up critical files to the user profile folder which are then restored on a fresh install.
Sometimes these logs are running to 10’s of GB’s (some folks convert a 1000 files a day) so backing them up probably won’t be feasible.
Makes sense, I guess it’s not a huge deal to to this by hand…
