Previouse Insatll Config
don’t have previous install config for preminum install. Nothing will process after instll of version 2.6.6
Open your mcebuddy.log file and read through to see what’s going on or attach it here. Can’t help without any logs or screenshots of your configuration.
(attachments)
mcebuddy.log (407 KB)
So it’s starting the conversion but the conversion is failing.
INFORMATION> 2025-07-16T15:07:09 MCEBuddy.Engine.Core → Job for C:\Users\retir\OneDrive\Desktop\Barnaby Jones S06E05 The Damocles Gun.mpeg started using conversion task → Convert to MP4 and profile → MP4 Normal
2025-07-16T15:07:09 MCEBuddy.Engine.Core → Temp working path is C:\Program Files\MCEBuddy2x\working0
2025-07-16T15:07:09 MCEBuddy.Engine.Core → Starting new conversions, allowing system sleep
INFORMATION> 2025-07-16T15:07:09 MCEBuddy.Engine.ConversionJob → Creating log file : C:\Program Files\MCEBuddy2x\log\Barnaby Jones S06E05 The Damocles Gun.mpeg-Convert to MP4-2025-07-16T15-07-09.log
INFORMATION> 2025-07-16T15:07:43 MCEBuddy.Engine.Core → Job for C:\Users\retir\OneDrive\Desktop\Barnaby Jones S06E05 The Damocles Gun.mpeg completed
INFORMATION> 2025-07-16T15:07:43 → Job for C:\Users\retir\OneDrive\Desktop\Barnaby Jones S06E05 The Damocles Gun.mpeg has Error Advertisement scan failed using conversion task
You will need to attach your conversion log or open it and scroll to the bottom and see what it’s failing. It shouldn’t start with ERROR>
I’m 79 I would not know what to look for, here is the last log file for the file that I attempted to convert…I do appreciate and your help…
(attachments)
Barnaby Jones S06E05 The Damocles Gun.mpeg-Convert to MP4-2025-07-16T15-07-09.log (505 KB)
Everything back on track now. Did a complete system clean for anything related to MCEBuddy, as recommened here. Somewhere there appeared to be a corrupt file that caused the proble. Rebooted, did a clean install of the current version. Now working. Thanks to all that provide input and comments they all helped.
Great. I also had a look at your logs. It appears that you had configured MCEBuddy to use a custom version of Comskip which was causing the failure
I also changed that. Thanks again.
