I finally got it to scan but still will not transfer
I uploaded a log under my name on the server Rickt1962 file Rickt1962-8-27-21
Hope someone who understands more than I do.
INFORMATION> → Starting conversion - DEBUG MESSAGES
INFORMATION> → License → Premium
INFORMATION> → Windows OS Version → Microsoft Windows NT 6.1.7601 Service Pack 1 (WIN_7_2008_SERVER_R2, Professional)
INFORMATION> → Windows Platform → 64 Bit
INFORMATION> → MCEBuddy Build Platform → 64 Bit
INFORMATION> → MCEBuddy Build Version : 2.5.6.1
INFORMATION> → MCEBuddy Build Date : 04/30/2021 16:24:00
INFORMATION> → MCEBuddy Running as Service : True
INFORMATION> → Manual Add Domain Name →
Manual Add User Name → Guest
Manual Add Password →
Archive Path Domain Name →
Archive Path User Name → Guest
Archive Path Password →
Failed Path Domain Name →
Failed Path User Name → Guest
Failed Path Password →
Alright I changed the path for conversion to Local Disk (D:) Scanned TV Shows
and nothing in the folder and nothing :frowning:
The issues appears to be related to the ability to execute comskip.exe
ERROR> 2021-08-26T22:14:42 MCEBuddy.AppWrapper.Comskip --> Application File Not Found or not accessible : C:\Program Files\MCEBuddy2x\comskip\comskip.exe
ERROR> 2021-08-26T22:14:42 MCEBuddy.CommercialScan.Scanner --> Comskip failed
ERROR> 2021-08-26T22:14:42 MCEBuddy.Engine.ConversionJob --> Advertisement scan failed
Check C:\Program Files\MCEBuddy2x\comskip\ and make sure comskip.exe is in there. If it is then I’m not sure why it can’t run it, if it isn’t then try uninstalling and reinstalling. Check that your antivirus application isn’t quarantining it.
Well its in the folder Local Disk (D):Program Files/MCEBuddy2x/Comskip/comskip.exe
When I click on comskip manually it flashes a second
Okay, so the problem is likely that you have it installed on the D drive but it’s looking on the C drive. Set your Comskip path in system settings using the browse button.
WOW Thats IT !!! Thank You ! now its working ! :slight_smile:
