I have been using Debut by NCH Software to record programs on my Mac. Until this week I had no problem with MCEBuddy processing these files. Up until now I was using the Debut Virtual Audio Device to record the audio but it has stopped working as of this week. I switched to Loopback by Rogue Amoeba to record the audio. The original MP4 file plays well but MCEBuddy 2.6 abandons the task of processing part way through. I was able to process a very short recording of 2 minutes using Debut & Loopback but the longer programs fail. I can attach the log files if necessary.
The final portion of the log for the failed attempt is below. Any assistance would be greatly appreciated.
CHAPTER INFO ->
2024-07-24T12:17:59 MCEBuddy.CommercialScan.Scanner --> EDL: Minimum segment size 4 seconds.
--> EDL Setting (ForceEDL) -> False
--> EDL Settings (ForceEDLP) -> False
2024-07-24T12:17:59 MCEBuddy.CommercialScan.Scanner --> EDL: Initial skip seconds adjustment 0 seconds.
INFORMATION> 2024-07-24T12:17:59 MCEBuddy.CommercialScan.Scanner --> Scanning commercials with Comskip
2024-07-24T12:17:59 MCEBuddy.AppWrapper.Comskip --> Launching process C:\Program Files\MCEBuddy2x\comskip\comskip.exe
2024-07-24T12:17:59 MCEBuddy.AppWrapper.Comskip --> Process arguments --output="C:\Program Files\MCEBuddy2x\working0" "C:\Program Files\MCEBuddy2x\working0\Shakespeare & Hathaway 202.ts"
2024-07-24T12:17:59 MCEBuddy.AppWrapper.Comskip --> UI Session Admin Process : True
2024-07-24T12:17:59 MCEBuddy.AppWrapper.Comskip --> Starting process as a UISession process with Admin privileges. This requires atleast 1 user to be logged into the system (remote desktop or locally)
2024-07-24T12:18:00 MCEBuddy.AppWrapper.Comskip --> Setting process priority to Normal
INFORMATION> 2024-07-24T12:18:00 MCEBuddy.AppWrapper.Comskip --> Process priority changed to Normal
ERROR> --> No response from process for 300 seconds, process likely hung - killing it
ERROR> --> Process hung, killing process
ERROR> 2024-07-24T12:23:02 MCEBuddy.CommercialScan.Scanner --> Comskip failed
ERROR> 2024-07-24T12:23:02 MCEBuddy.Engine.ConversionJob --> Advertisement scan failed
INFORMATION> 2024-07-24T12:23:02 MCEBuddy.Engine.ConversionJob -->
--> Performance Metrics for the Current Conversion
--> Working video pre-conversion duration (hh:mm:ss) -> 01:00:20
2024-07-24T12:23:02 MCEBuddy.Engine.ConversionJob --> Original file size [KB] 8,176,977.00
--> <Start At Date/Time> <Duration (hh:mm:ss)> <Activity>
--> <07/24/2024 12:15:51> <00:00:03> <Checking for disk space>
--> <07/24/2024 12:15:54> <00:00:00> <Running custom commands>
--> <07/24/2024 12:15:54> <00:00:02> <Getting show information and banner from Internet sources>
--> <07/24/2024 12:15:57> <00:00:06> <Running custom commands>
--> <07/24/2024 12:16:03> <00:01:46> <Remuxing recording>
--> <07/24/2024 12:17:50> <00:00:00> <Trimming video recording>
--> <07/24/2024 12:17:50> <00:00:07> <Analyzing video information>
--> <07/24/2024 12:17:57> <00:05:05> <Advertisement scan>
INFORMATION> --> Total time taken by conversion (hh:mm:ss) -> 00:07:10
