Failed Conversion - Comskip
I keep getting failed process. I input the file (OTA Recording from HDHomeRun). Each time the MCEBuddy 2.6.6 will not process..
12 O’Clock High S02E19 [20260201-0500].mpg-Convert to MP4-2026-02-02T08-01-57.log (508.5 KB)
Thanks for the logs. It appears that you’re using a custom build of Comskip that using a very old code base (0.80.038) which is causing Comskip to fail.
Custom Comskip Path → C:\Users\budko\Downloads\comskip80_038\comskip.exe
2026-02-02T08:02:38 MCEBuddy.AppWrapper.Comskip → Errors:
2026-02-02T08:02:38 MCEBuddy.AppWrapper.Comskip → ComSkip: invalid option “–output=C:\Program Files\MCEBuddy2x\working0”
2026-02-02T08:02:38 MCEBuddy.AppWrapper.Comskip → Comskip 0.80.038, made using:
2026-02-02T08:02:38 MCEBuddy.AppWrapper.Comskip → mpeg2dec-0.4.0 - by Michel Lespinasse walken@zoy.org and Aaron Holtzman
→ Process exited with code 2
WARNING> 2026-02-02T08:02:40 MCEBuddy.AppWrapper.Comskip → Comskip failed
I would recommend using the latest Comskip version or use the default version of Comskip that ships with MCEBuddy (it’s extremely fast, optimized for hardware acceleration, supports upto 16k resolutions and has a few more features). That should fix your issue.
