Upgraded MCEBuddy and now comericals aren't removing?
Hello, for a long time I have been using “MCEBuddy 2.4.6 64bit” and “comskip81_092_donators” and it was working great without any issues. MCEBuddy kept informing me that version is no longer supported, so I decided to upgrade expecting things to be the same, or better. However what I found was that now its not working, and I’m not sure why so hopefully someone can help me!
I am a premium supporter of both MCEBuddy and Comskip, so first I uninstalled the old versions and then downloaded and installed “MCEBuddy 2.4.10 64bit - 20190313” and “comskip82_007_donators” I double checked all the settings (I had taken screenshots before I uninstalled the old version so I could compare) and everything looked good. I then figured there was something wrong with the beta, so I uninstalled that and went with the latest stable version, “MCEBuddy 2.4.9 64bit” but had the same problems. I tried both the donators version of Comskip, and the version included by MCEBuddy but in all cases, the file “processes” successfully, but the commercials are not removed. I looked in “history” and the results are the same as several weeks ago before I tried upgrading everything.
Here is a conversion log where I tried to re-process one of the recordings that the recordings were still present:
News @ 6PM_WJLAHD_2019_03_11_17_59_00 (1).wtv-Remove Ads-2019-03-17T20-24-49.6219972-04-00.log (627.7 KB)
Any help would be greatly appreciated!
Thanks,
Scott
Looked at your log and you got the same thing i did. Comskip 82.7 comes up free version in mcebuddy and will not preform the cuts. i downgraded to Comskip 82.2 and all is fine again.
There’s a problem with your Comskip. It doesn’t appear to be running and exits with an error:
INFORMATION> 2019-03-17T20:25:31 MCEBuddy.CommercialScan.Scanner –> Scanning commercials with Comskip
2019-03-17T20:25:31 MCEBuddy.AppWrapper.Comskip –> Launching process C:\Users\HTPC\Downloads\comskip82_007_donators\comskip.exe
2019-03-17T20:25:31 MCEBuddy.AppWrapper.Comskip –> Process arguments --ini=“C:\Program Files\MCEBuddy2x\comskip\comskip.ini” --output=“T:\MCE Buddy Archive\temp\working0” “T:\MCE Buddy Archive\temp\working0\News @ 6PM_WJLAHD_2019_03_11_17_59_00 (1).ts”
2019-03-17T20:25:31 MCEBuddy.AppWrapper.Comskip –> UI Session Admin Process : True
2019-03-17T20:25:31 MCEBuddy.AppWrapper.Comskip –> Starting process as a UISession process with Admin privileges. This requires atleast 1 user to be logged into the system (remote desktop or locally) 2019-03-17T20:25:31 MCEBuddy.AppWrapper.Comskip –> Setting process priority to Normal –> Process exited with code 255
2019-03-17T20:25:34 MCEBuddy.CommercialScan.Scanner –> Commercial Scan: Percentage Complete 0
INFORMATION> 2019-03-17T20:25:34 MCEBuddy.CommercialScan.Scanner –> Skipping EDLP, using EDL file for commercial removal
WARNING> 2019-03-17T20:25:34 MCEBuddy.CommercialScan.Scanner –> Cannot find or access EDL File
Try using the built in version that ships with MCEBuddy (0.82.003) or an older version of Comskip.
It appears to be an issue your custom comskip location or file permissions etc. I just did a test on the version you’re using and it’s working fine. This is what the logs look like when it’s accessible
→ Checking for donator version of Comskip
2019-03-18T16:30:24 MCEBuddy.AppWrapper.Comskip → Launching process D:\MCEBuddy\MCEBuddy2x\MCEBuddy.ServiceCMD\bin\x64\Debug\comskip\comskip.exe
2019-03-18T16:30:24 MCEBuddy.AppWrapper.Comskip → Process arguments -h
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → Setting process priority to Normal
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → The commandline used was:
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → Comskip 0.82.007, made using ffmpeg
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → D:\MCEBuddy\MCEBuddy2x\MCEBuddy.ServiceCMD\bin\x64\Debug\comskip\comskip.exe -h
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → Donator build
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → Usage:
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → comskip [-h|–help] [-w|–debugwindow] [-n|–playnice] [–zpcut] [–zpchapter] [–scf] [–videoredo] [–videoredo3] [–csvout] [–quality] [–plist] [-m|–demux] [–hwassist] [–cuvid] [–vdpau] [–dxva2] [–decoders] [–threads=] [-p|–pid=] [-t|–ts] [-d|–detectmethod=] [-v|–verbose=] [-u|–dump=] [-s|–play] [–timing] [-q|–quiet] [–ini=] [–logo=] [–cut=] [–output=] [–output-filename=] [–selftest=] []
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → -h, --help Display syntax
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → -w, --debugwindow Show debug window
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → -n, --playnice Slows detection down
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → --zpcut Outputs a ZoomPlayer cutlist
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → --zpchapter Outputs a ZoomPlayer chapter file
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → --scf Outputs a simple chapter file for mkvmerge
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → --videoredo Outputs a VideoRedo cutlist
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → --videoredo3 Outputs a VideoRedo3 cutlist
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → --csvout Outputs a csv of the frame array
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → --quality Outputs a csv of false detection segments
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → --plist Outputs a mac-style plist for addition to an EyeTV archive as the ‘markers’ property
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → -m, --demux Demux the input into elementary streams
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → --hwassist Activate Hardware Assisted video decoding
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → --cuvid Use NVIDIA Video Decoder (CUVID), if available
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → --vdpau Use NVIDIA Video Decode and Presentation API (VDPAU), if available
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → --dxva2 Use DXVA2 Video Decode and Presentation API (DXVA2), if available
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → --decoders List all decoders and exit
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → --threads= The number of threads to use
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → -p, --pid= The PID of the video in the TS
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → -t, --ts The input file is a Transport Stream
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → -d, --detectmethod= An integer sum of the detection methods to use
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → -v, --verbose= Verbose level
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → -u, --dump= Dump the cutscene at this frame number
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → -s, --play Play the video
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → --timing Dump the timing into a file
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → -q, --quiet Not output logging to the console window
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → --ini= Ini file to use
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → --logo= Logo file to use
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → --cut= CutScene file to use
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → --output= Folder to use for all output files
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → --output-filename= Filename base to use for all output files
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → --selftest= Execute a selftest
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → Input file
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → Output folder for cutlist
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → Detection Methods
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → 1 - Black Frame
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → 2 - Logo
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → 4 - Scene Change
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → 8 - Resolution Change
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → 16 - Closed Captions
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → 32 - Aspect Ratio
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → 64 - Silence
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → 128 - CutScenes
2019-03-18T16:30:32 MCEBuddy.AppWrapper.Comskip → 255 - USE ALL AVAILABLE
INFORMATION> → Comskip version : DONATOR
Where as in your case it’s not even running and exiting with code 255. I think it’s a file permission issue with your comskip setup. Try using the built in version that ships with MCEBuddy and then move onto your custom version and check that the file is accessible to all users.
Thanks for the help everyone! It appears there are indeed issues with new version, I also came across these: link 1, link 2. Its odd that the comskip team acknowledged this and took down the newer version, then later put it back with the same issues. I’ve changed over to the old version I was using before, and now everything is working perfectly again! Thanks!
