I have some MP4 files that when converted (it doesn’t matter what settings I use) produce files with only Audio and no Video. I’m converting these because ChannelsDVR FireTV Client won’t play them unless Software Decoding is enabled, and when that’s enabled, nothing else plays.
Here is the information on the input file. As luck and fortune would have it, the log files is more than 10Megs so it would upload here, so that’s awesome.
General
Complete name : C:\Users\edward\Videos\MCEBuddyVideoIN\Logan’s Run - s01e01 - Logan’s Run.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom/iso2/mp41)
File size : 769 MiB
Duration : 1 h 13 min
Overall bit rate mode : Variable
Overall bit rate : 1 462 kb/s
Collection : Logan’s Run
Season : 1
Album/Performer : Logan’s Run
Part : 1
Part/Position : 1
Part/Total : 1
Track name : Logan’s Run
Track name/Position : 1
Genre : Sci-Fi & Fantasy
Description : Logan leaves the City of Domes with Jessica and they are kidnapped by a pair of robots. An android named Rem rescues them and they flee with Francis in pursuit.
Recorded date : 1977
Encoded date : UTC 1970-01-01 00:00:00
Tagged date : UTC 2009-06-29 18:37:02
Cover : Yes
Part_ID : S1E1
Video
Format : MPEG-4 Visual
Format profile : Simple@L1
Format settings, BVOP : No
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : mp4v-20
Bit rate : 1 328 kb/s
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 30.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.144
Stream size : 699 MiB (91%)
Writing library : Lavc52.1.0
Tagged date : UTC 1970-01-01 00:00:00
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Bit rate mode : Variable
Bit rate : 128 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Stream size : 67.3 MiB (9%)
