MCEBuddy deleting the original but not converting
MCEBuddy in the last few days has been deleting the original but not converting (so I have no shows) in the logs it says it took zero time converting… I am using the paid version…
Attach the logs
also the cbs morning only got half of the show
(not sure what happened there)
thanks for looking at this
mcebuddy.zip (84.8 KB)
It’s behaving exactly as you’ve configured it:
In your Conversion Task Expert Setting you’ve enabled the option Do not overwrite files
Skip ReProcessing → True
So it checks for that and does exactly that:
INFORMATION> 2017-09-25T15:21:40 MCEBuddy.Engine.ConversionJob → Checking for destination file skip reprocessing
→ Custom Renaming Command → 1%showname%%showname% - %episodename% - %airyear%%airmonth%%airday%
WARNING> 2017-09-25T15:21:40 MCEBuddy.Engine.ConversionJob → Destination file D:\TV2\1\Bewitched\Bewitched - Ling Ling - 1965_02_11.ts EXISTS, skipping conversion - SUCCESSFUL processing
It marks the conversion as Successful because that’s what you configured it to do above and since you’ve Enabled the option for Delete Original File on successful completion it does exactly that.
thank you so much for your kind help
I will look at that
