Hi,
I’ve had my setup working for a while now. I haven’t done any changes to it.
Up until the 26/09, my conversion process was working fine for a TV Recording. But last week it stopped working, no apparent reason. I’ve tried to convert the files by manually adding them to MCE, it looks like it’s processing but at the end of the process there’s no output on the output folder.
I grabbed the last working recording and re-processed it and it worked fine, so I don’t know why the new recordings are not been processed. haven’t seen any different in the logs.
Home And Away_20190926_19001930.ts-WORKED.log (358.4 KB) Home And Away_20190930_19001932.ts-NOT WORKED.log (364.2 KB) mcebuddy-TRIMMED.log (34.4 KB)
MCE v2.4.10 not converting videos
If it’s failed, then you’ll see why at the bottom of the logs. Search for ERROR>
MCEBuddy.AppWrapper.CCExtractor --> 6% | 02:01
–> Process exited with code 255
ERROR> --> CCExtractor failed to extract closed captions
ERROR> 2019-10-10T09:09:03 MCEBuddy.Engine.ConversionJob --> Extracting closed captions failed
If you have the original file that failed please upload it to our server so we can analyze it and possibly have a fix for it
Both log files have the same error message, but the first one worked.
I have the files, but they are large .ts files. Where do I upload them?
You can find the instructions here:
Thanks Goose,
I’ve uploaded 1 chunk of each file, not sure if that’s enough. can upload the whole file if needed.
Yes in this case I’ll need the whole file since the failure may not be at the beginning
Files are uploaded
Thanks, there’s an issue with the underlying ccextractor, we’ve put a workaround and it should work in the next BETA build.
does that mean that if I remove the extracting subtitles from the process for now, it should work?
You can download the latest beta build and it should work
Hi Goose,
Thanks, it’s working now. However I just encountered another issue.
The show I record sometime airs 2 or 3 times in one day. My solution to this was to custom name the conversion with show_date_time and then handle it in Plex. This was working fine in the past, however I noticed since the beta update, it’s not picking up the time from the recoded filename.
The original recorded filename has Show_date_time.ts and in the past this was working fine for the converted file. Now after converstion I get Show_date_0000 (time as 00:00) when the TV airs more than once a day, the converted file overwrites the previous one. Is there a way to keep them (other than adding time to the filename)?
Conversion log?
uploaded to ftp location. 3 log files
Thanks for reporting it, we’ve fixed this and it should be available in the next 2.5.1 beta build.
