MCEBuddy.AppWrapper.FFmpeg --> [matroska @ 000001f5b724b040] Timestamps are unset in a packet for stream 1. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly
2020-01-01T13:04:19 MCEBuddy.AppWrapper.FFmpeg --> [matroska @ 000001f5b724b040] Can’t write packet with unknown timestamp
2020-01-01T13:04:19 MCEBuddy.AppWrapper.FFmpeg --> av_interleaved_write_frame(): Invalid argument
2020-01-01T13:04:19 MCEBuddy.AppWrapper.FFmpeg --> Error writing trailer of C:\Program Files\MCEBuddy2x\working0\Match of the Day 2_20191229_22302335-converted.mkv: Invalid argument
I am also having the same issue and i didn’t have mcebuddy previous to this version so I don’t know if a newer version is causing the problem
2020-01-07T14:15:19 MCEBuddy.AppWrapper.FFmpeg --> [matroska @ 000002660b28e040] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly
2020-01-07T14:15:19 MCEBuddy.AppWrapper.FFmpeg --> [matroska @ 000002660b28e040] Can't write packet with unknown timestamp
2020-01-07T14:15:19 MCEBuddy.AppWrapper.FFmpeg --> av_interleaved_write_frame(): Invalid argument
2020-01-07T14:15:19 MCEBuddy.AppWrapper.FFmpeg --> frame=24237 fps=13991 q=-1.0 Lsize= 266047kB time=00:13:30.86 bitrate=2687.8kbits/s speed= 468x
2020-01-07T14:15:19 MCEBuddy.AppWrapper.FFmpeg --> video:253211kB audio:12649kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.070291%
2020-01-07T14:15:19 MCEBuddy.AppWrapper.FFmpeg --> Conversion failed!
Changing to mp4 unprocessed fixes the issue
These are files recorded from Channels TVE mode - about 60-70 percent from this specific channel are having the issue
