I have quite a lot of WTV files from WMC files I need to convert. I installed MCEBuddy and started a single conversion but it’s going to take over an hour for an hour long program.
This machine is a bit older, built back in 2013. The GPU is a Radeon HD7870, so I don’t think I can use hardware acceleration, right?
My CPU is AMD FX-6300 3.5GHz
Is this about average for my build or can I speed this entire process up? The commercial scan part wasn’t that long, but the full conversion is what’s taking almost an hour per hour of raw video.
First few recoirdings were missing subtitles, so I went ahead and added that support with the OCR install. Now I’m looking at almost 90 minutes per raw hour of video to convert.
Software conversion can take time depending on your profile, for example if you’re converting mpeg2 video to h.264 or h.265, it can be quite processor intensive. If you don’t want to convert the video format use an unprocessed profile and it’ll be much much faster.
AMD hardware conversion was just released starting in latest 2.5.1 build.
A profile with the name unprocessed in it, like TS Unprocessed or MP4 Unprocessed. You can find a short description about each profile when you select it.
Ok that is super fast now with AMD and unprocessed selected. The Comskip part is now the longest. I barely even noticed the video processing time. It went right to the next video before I even noticed.
