Handbrake crashing with hardware encoding on new PC
I built a new PC and have an intel motherboard/CPU but an AMD GPU. When doin x265 encodes MY PC would convert a 24min anime show in about 20-30min. I tried using the AMD VCE setting and was amazed when the same file converted in about 2 min. I was able to convert a season of shows, once. I noticed there were some frames where the encoding looked pixelated so I was going to try adjusting the preset tune from balanced to quality. since the first time I have not been able to consistently get any setting to complete an encode using the AMD VCE encoder. All my encodes began failing after about 5-10 seconds usually with the app crashing. I tried changing my power settings from balanced to high performance and was able to get to about 90% before the encode would fail or HB would crash. When the app doesn’t crash and I am able to see the logs I noticed in the logs handbrake keeps trying to load nvEncodeAPI64.dll… which is for NVidia?
I tried downloading the .dll and placing it into the System 32 folder and then the log error says unable to load nvcuda.dll (also an NVIDIA library) after adding that dll the error log then says “Cannot load cuDevicePrimaryCtxRetain” The encodes fail after only a couple seconds so I removed both dll files from the system 32 folder. I cannot get HB to consistently complete any encodes using the AMD VCE encoder now. Progress seemed to get a little further using AMD VCE over the 10-bit AMD VCE but neither reliably complete an encode. Switching back to just H.265 I am once again able to get the same video to encode but it takes about 20-30 mins and the quality is not as good as the one time I was able to complete an encode using the AMD VCE setting and it succeeded. After seeing the result of using the AMD VCE encoder I would really like to get it to be reliable but seem unable to figure out why the encodes keep failing and the app keeps crashing?
Windows 11 Pro Version 23H2
Installed on 4/‎7/‎2024
OS build 22631.2861
Windows Feature Experience Pack 1000.22681.1000.0
Motherboard: TX GAMING B760M WIFI
CPU: Intel i13700KF
GPU: Radeon RX 7800 XT 16G GDDR6
PSU: ROG-STRIX-850G-WHITE
RAM: ADATA XPG Lancer RGB 32GB DDR5-7200
Will need the conversion logs to see what’s going on. If handbrake itself is crashing then it could be a bad graphics driver. Also try to update handbrake by downloading the latest 64bit build and replacing it in the mcebuddy installation folder and see if that helps.
I believe 1.7.3 is the latest version… how would I do the update you recommended? I have one of my conversion logs on the handbrake forum. I’ll try to find a link
HandBrake 1.7.3 (2024021000)
OS: Microsoft Windows NT 10.0.22631.0
CPU: 13th Gen Intel(R) Core™ i7-13700KF
Ram: 32577 MB,
GPU Information:
AMD Radeon RX 7800 XT - 31.0.24027.1012
Screen: 2048x1152
Temp Dir: C:\Users\User\AppData\Local\Temp
Install Dir: C:\Applications\HandBrake
Data Dir: C:\Users\User\AppData\Roaming\HandBrake
 # Starting Encode ...
[03:38:19] base preset: Anime (Modified)
[03:38:19] hb_init: starting libhb thread
[03:38:19] Starting work at: Wed Apr 10 03:38:19 2024
[03:38:19] 1 job(s) to process
[03:38:19] json job:
  "Audio": {
    "AudioList": [
        "DRC": 0,
        "Encoder": "copy:aac",
        "Gain": 0,
        "Mixdown": -1,
        "NormalizeMixLevel": false,
        "Samplerate": 0,
        "Track": 1,
        "DitherMethod": 0
        "DRC": 0,
        "Encoder": "copy:eac3",
        "Gain": 0,
        "Mixdown": -1,
        "Samplerate": 0,
        "Track": 3,
        "DitherMethod": 0
    "CopyMask": [
      "copy:aac",
      "copy:ac3",
      "copy:dtshd",
      "copy:dts",
      "copy:mp3",
      "copy:truehd",
      "copy:flac",
      "copy:eac3",
      "copy:mp2"
    "FallbackEncoder": "av_aac"
  "Destination": {
    "ChapterList": [
        "Name": "Intro"
        "Name": "Scene 1"
        "Name": "Scene 2"
        "Name": "Scene 3"
        "Name": "Credits"
    "ChapterMarkers": true,
    "AlignAVStart": false,
    "File": "C:\\Users\\User\\Videos\\Sand Land The Series S01E01 - The Story of the Fiend Prince EP1 Departure.mkv",
    "Options": {
      "IpodAtom": false,
      "Optimize": false
    "Mux": "av_mkv"
  "Filters": {
    "FilterList": [
        "ID": 5,
        "Settings": {
          "mode": "23"
        "ID": 4,
        "Settings": {
          "block-height": "16",
          "block-thresh": "40",
          "block-width": "16",
          "filter-mode": "2",
          "mode": "3",
          "motion-thresh": "1",
          "spatial-metric": "2",
          "spatial-thresh": "1"
        "ID": 19,
        "Settings": {
          "crop-bottom": "0",
          "crop-left": "0",
          "crop-right": "0",
          "crop-top": "0",
          "height": "1080",
          "width": "1920"
        "ID": 10,
        "Settings": {
          "mode": "0"
  "PAR": {
    "Num": 1,
    "Den": 1
  "Metadata": {
    "Artist": "Mutsumi Tamura, Kazuhiro Yamaji, Ch\u00F4, Satoshi Tsuruoka, Nobuo Tobita, Chafuurin, Mikako Komatsu, Ayumu Murase, Akio Otsuka, Tomokazu Sugita, Kouji Yusa, Hiroyuki Yoshino, Masafumi Kobatake",
    "Comment": "In the barren Sand Land, a human named Sheriff Rao decides to head out in search of the Legendary Spring to save his people who are dying of thirst. The Fiend Prince Beelzebub and the demon burglar, Thief, soon join him, but what awaits the unlikely trio are desert monsters and nefarious bandits.",
    "Description": "In the barren Sand Land, a human named Sheriff Rao decides to head out in search of the Legendary Spring to save his people who are dying of thirst. The Fiend Prince Beelzebub and the demon burglar, Thief, soon join him, but what awaits the unlikely trio are desert monsters and nefarious bandits.",
    "Genre": "Fantasy, Animation, Adventure, Action, Anime",
    "LongDescription": "In the barren Sand Land, a human named Sheriff Rao decides to head out in search of the Legendary Spring to save his people who are dying of thirst. The Fiend Prince Beelzebub and the demon burglar, Thief, soon join him, but what awaits the unlikely trio are desert monsters and nefarious bandits.",
    "Name": "The Story of the Fiend Prince EP1: Departure",
    "ReleaseDate": "2024-03-20"
  "SequenceID": 0,
  "Source": {
    "Angle": 1,
    "Range": {
      "Type": "chapter",
      "Start": 1,
      "End": 5
    "Title": 1,
    "Path": "C:\\Users\\User\\Downloads\\Media\\Sand Land The Series S01E01 - The Story of the Fiend Prince EP1 Departure.mkv",
    "HWDecode": 0
  "Subtitle": {
    "Search": {
      "Burn": false,
      "Default": false,
      "Enable": false,
      "Forced": false
    "SubtitleList": [
        "Burn": false,
        "Default": false,
        "Forced": false,
        "ID": 1,
        "Offset": 0,
        "Track": 0
        "Burn": false,
        "Default": true,
        "Forced": false,
        "ID": 2,
        "Offset": 0,
        "Track": 1
  "Video": {
    "Encoder": "vce_h265",
    "Level": "auto",
    "Bitrate": 1450,
    "MultiPass": false,
    "Turbo": false,
    "ColorMatrixCode": 0,
    "Options": "Preset: Animation",
    "Preset": "quality",
    "Profile": "main",
    "QSV": {
      "Decode": false
    "HardwareDecode": 0
[03:38:19] CPU: 13th Gen Intel(R) Core(TM) i7-13700KF
[03:38:19]  - logical processor count: 24
[03:38:19] Intel Quick Sync Video support: no
[03:38:19] hb_scan: path=C:\Users\User\Downloads\Media\Sand Land The Series S01E01 - The Story of the Fiend Prince EP1 Departure.mkv, title_index=1
Input #0, matroska,webm, from 'C:\Users\User\Downloads\Media\Sand Land The Series S01E01 - The Story of the Fiend Prince EP1 Departure.mkv':
  Metadata:
    encoder         : libebml v1.4.5 + libmatroska v1.7.1
    TITLE           : The Story of the Fiend Prince EP1: Departure
    ARTIST          : Mutsumi Tamura, Kazuhiro Yamaji, Chô, Satoshi Tsuruoka, Nobuo Tobita, Chafuurin, Mikako Komatsu, Ayumu Murase, Akio Otsuka, Tomokazu Sugita, Kouji Yusa, Hiroyuki Yoshino, Masafumi Kobatake
    ACTOR           : Mutsumi Tamura, Kazuhiro Yamaji, Chô, Satoshi Tsuruoka, Nobuo Tobita, Chafuurin, Mikako Komatsu, Ayumu Murase, Akio Otsuka, Tomokazu Sugita, Kouji Yusa, Hiroyuki Yoshino, Masafumi Kobatake
    GENRE           : Fantasy, Animation, Adventure, Action, Anime
    DATE_RELEASED   : 2024-03-20
    DATE_RELEASE    : 2024-03-20
    DATE_RECORDED   : 2024-03-20
    CONTENT_TYPE    : TV Show
    EPISODE.PART_NUM: 1
    SEASON.PART_NUM : 1
    DESCRIPTION     : In the barren Sand Land, a human named Sheriff Rao decides to head out in search of the Legendary Spring to save his people who are dying of thirst. The Fiend Prince Beelzebub and the demon burglar, Thief, soon join him, but what awaits the unlikely trio
    SUMMARY         : In the barren Sand Land, a human named Sheriff Rao decides to head out in search of the Legendary Spring to save his people who are dying of thirst. The Fiend Prince Beelzebub and the demon burglar, Thief, soon join him, but what awaits the unlikely trio
    SYNOPSIS        : In the barren Sand Land, a human named Sheriff Rao decides to head out in search of the Legendary Spring to save his people who are dying of thirst. The Fiend Prince Beelzebub and the demon burglar, Thief, soon join him, but what awaits the unlikely trio
    SORT_WITH       : Sand Land: The Series S01E01
    COLLECTION/TITLE: Sand Land: The Series
    EPISODE/PART_NUMBER: 1
    EPISODE/TITLE   : The Story of the Fiend Prince EP1: Departure
    SEASON/PART_NUMBER: 1
  Duration: 00:24:02.05, start: 0.000000, bitrate: 6801 kb/s
  Chapters:
    Chapter #0:0: start 0.000000, end 12.541000
      Metadata:
        title           : Intro
    Chapter #0:1: start 12.541000, end 250.666000
      Metadata:
        title           : Scene 1
    Chapter #0:2: start 250.666000, end 834.333000
      Metadata:
        title           : Scene 2
    Chapter #0:3: start 834.333000, end 928.041000
      Metadata:
        title           : Scene 3
    Chapter #0:4: start 928.041000, end 928.041000
      Metadata:
        title           : Credits
  Stream #0:0: Video: h264 (High), yuv420p(tv, bt709, progressive), 1920x1080 [SAR 1:1 DAR 16:9], 24 fps, 24 tbr, 1k tbn (default)
    Metadata:
      BPS             : 6160054
      DURATION        : 00:24:02.000000000
      NUMBER_OF_FRAMES: 34608
      NUMBER_OF_BYTES : 1110349873
      _STATISTICS_WRITING_APP: mkvmerge v83.0 ('Circle Of Friends') 64-bit
      _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
  Stream #0:1(ger): Audio: aac (LC), 48000 Hz, stereo, fltp (default)
    Metadata:
      BPS             : 125376
      DURATION        : 00:24:02.048000000
      NUMBER_OF_FRAMES: 67596
      NUMBER_OF_BYTES : 22599953
  Stream #0:2(eng): Audio: aac (LC), 48000 Hz, stereo, fltp
    Metadata:
      BPS             : 125375
      NUMBER_OF_BYTES : 22599758
  Stream #0:3(fre): Audio: aac (LC), 48000 Hz, stereo, fltp
    Metadata:
      title           : European
      BPS             : 125375
      NUMBER_OF_BYTES : 22599756
  Stream #0:4(jpn): Audio: eac3, 48000 Hz, 5.1(side), fltp, 256 kb/s
    Metadata:
      BPS             : 256000
      NUMBER_OF_FRAMES: 45064
      NUMBER_OF_BYTES : 46145536
  Stream #0:5(jpn): Subtitle: subrip
    Metadata:
      BPS             : 115
      DURATION        : 00:23:28.167000000
      NUMBER_OF_FRAMES: 463
      NUMBER_OF_BYTES : 20338
  Stream #0:6(jpn): Subtitle: none
    Metadata:
      title           : SDH
      BPS             : 179
      NUMBER_OF_FRAMES: 464
      NUMBER_OF_BYTES : 31516
  Stream #0:7(cze): Subtitle: none
    Metadata:
      BPS             : 99
      DURATION        : 00:23:36.750000000
      NUMBER_OF_FRAMES: 373
      NUMBER_OF_BYTES : 17668
  Stream #0:8(dan): Subtitle: none
    Metadata:
      BPS             : 99
      NUMBER_OF_BYTES : 17642
  Stream #0:9(ger): Subtitle: none
    Metadata:
      BPS             : 106
      NUMBER_OF_FRAMES: 366
      NUMBER_OF_BYTES : 18914
  Stream #0:10(gre): Subtitle: none
    Metadata:
      BPS             : 145
      NUMBER_OF_BYTES : 25757
  Stream #0:11(eng): Subtitle: subrip
    Metadata:
      BPS             : 61
      NUMBER_OF_FRAMES: 375
      NUMBER_OF_BYTES : 10911
  Stream #0:12(eng): Subtitle: none
    Metadata:
      title           : SDH
      BPS             : 114
      DURATION        : 00:23:48.834000000
      NUMBER_OF_FRAMES: 435
      NUMBER_OF_BYTES : 20408
  Stream #0:13(spa): Subtitle: none
    Metadata:
      title           : Latin American
      BPS             : 101
      NUMBER_OF_FRAMES: 374
      NUMBER_OF_BYTES : 17940
  Stream #0:14(spa): Subtitle: none
    Metadata:
      title           : European
      BPS             : 109
      NUMBER_OF_FRAMES: 364
      NUMBER_OF_BYTES : 19374
  Stream #0:15(fin): Subtitle: none
    Metadata:
      BPS             : 96
      NUMBER_OF_FRAMES: 372
      NUMBER_OF_BYTES : 17159
  Stream #0:16(fre): Subtitle: none
    Metadata:
      title           : European
      BPS             : 107
      NUMBER_OF_BYTES : 18982
  Stream #0:17(hun): Subtitle: none
    Metadata:
      BPS             : 101
      NUMBER_OF_FRAMES: 367
      NUMBER_OF_BYTES : 18044
  Stream #0:18(ita): Subtitle: none
    Metadata:
      BPS             : 99
      NUMBER_OF_FRAMES: 371
      NUMBER_OF_BYTES : 17675
  Stream #0:19(kor): Subtitle: subrip
    Metadata:
      BPS             : 77
      NUMBER_OF_FRAMES: 386
      NUMBER_OF_BYTES : 13668
  Stream #0:20(kor): Subtitle: none
    Metadata:
      title           : SDH
      BPS             : 135
      NUMBER_OF_FRAMES: 446
      NUMBER_OF_BYTES : 24145
  Stream #0:21(dut): Subtitle: none
    Metadata:
      BPS             : 91
      NUMBER_OF_FRAMES: 335
      NUMBER_OF_BYTES : 16174
  Stream #0:22(nor): Subtitle: none
    Metadata:
      BPS             : 94
      NUMBER_OF_FRAMES: 357
      NUMBER_OF_BYTES : 16714
  Stream #0:23(pol): Subtitle: none
    Metadata:
      BPS             : 97
      NUMBER_OF_FRAMES: 369
      NUMBER_OF_BYTES : 17308
  Stream #0:24(por): Subtitle: none
    Metadata:
      title           : Brazilian
      BPS             : 102
      NUMBER_OF_FRAMES: 368
      NUMBER_OF_BYTES : 18207
  Stream #0:25(por): Subtitle: none
    Metadata:
      title           : European
      BPS             : 104
      NUMBER_OF_BYTES : 18527
  Stream #0:26(rum): Subtitle: none
    Metadata:
      BPS             : 95
      NUMBER_OF_FRAMES: 316
      NUMBER_OF_BYTES : 16898
  Stream #0:27(slo): Subtitle: none
    Metadata:
      BPS             : 95
      NUMBER_OF_BYTES : 16955
  Stream #0:28(swe): Subtitle: none
    Metadata:
      BPS             : 96
      NUMBER_OF_FRAMES: 370
      NUMBER_OF_BYTES : 17088
  Stream #0:29(tur): Subtitle: none
    Metadata:
      BPS             : 98
      NUMBER_OF_BYTES : 17426
  Stream #0:30(chi): Subtitle: none
    Metadata:
      title           : Traditional
      BPS             : 97
      NUMBER_OF_BYTES : 17250
[03:38:19] add_ffmpeg_subtitle: unknown subtitle stream type: 0x0
[03:38:19] scan: decoding previews for title 1
[03:38:19] scan: audio 0x1: aac, rate=48000Hz, bitrate=1 Deutsch (AAC LC, 2.0 ch)
[03:38:19] scan: audio 0x2: aac, rate=48000Hz, bitrate=1 English (AAC LC, 2.0 ch)
[03:38:19] scan: audio 0x3: aac, rate=48000Hz, bitrate=1 Francais (AAC LC, 2.0 ch)
[03:38:19] scan: audio 0x4: eac3, rate=48000Hz, bitrate=256000 ??? (E-AC3, 5.1 ch, 256 kbps)
[03:38:19] using container PAR 1:1
[03:38:19] scan: 10 previews, 1920x1080, 24.000 fps, autocrop = 0/0/0/0, aspect 16:9, PAR 1:1, color profile: 1-1-1, chroma location: left
[03:38:19] libhb: scan thread found 1 valid title(s)
[03:38:19] Starting Task: Encoding Pass
[03:38:19] work: skipping crop/scale filter
[03:38:19] job configuration:
[03:38:19]  * source
[03:38:19]    + C:\Users\User\Downloads\Media\Sand Land The Series S01E01 - The Story of the Fiend Prince EP1 Departure.mkv
[03:38:19]    + title 1, chapter(s) 1 to 5
[03:38:19]    + container: matroska,webm
[03:38:19]    + data rate: 6801 kbps
[03:38:19]  * destination
[03:38:19]    + C:\Users\User\Videos\Sand Land The Series S01E01 - The Story of the Fiend Prince EP1 Departure.mkv
[03:38:19]    + container: Matroska (libavformat)
[03:38:19]      + chapter markers
[03:38:19]  * video track
[03:38:19]    + decoder: h264 8-bit (yuv420p)
[03:38:19]    + filters
[03:38:19]      + Comb Detect (mode=3:spatial-metric=2:motion-thresh=1:spatial-thresh=1:filter-mode=2:block-thresh=40:block-width=16:block-height=16)
[03:38:19]      + Decomb (mode=55)
[03:38:19]      + Framerate Shaper (mode=0)
[03:38:19]        + frame rate: same as source (around 24.000 fps)
[03:38:19]    + Output geometry
[03:38:19]      + storage dimensions: 1920 x 1080
[03:38:19]      + pixel aspect ratio: 1 : 1
[03:38:19]      + display dimensions: 1920 x 1080
[03:38:19]    + encoder: H.265 (AMD VCE)
[03:38:19]      + preset:  quality
[03:38:19]      + options: Preset: Animation
[03:38:19]      + profile: main
[03:38:19]      + level:   auto
[03:38:19]      + bitrate: 1450 kbps, pass: 0
[03:38:19]      + color profile: 1-1-1
[03:38:19]      + chroma location: left
[03:38:19]  * subtitle track 1, ??? (UTF-8) (track 0, id 0x5, Text) -> Passthrough
[03:38:19]  * subtitle track 2, English (UTF-8) (track 1, id 0xb, Text) -> Passthrough, Default
[03:38:19]  * audio track 1
[03:38:19]    + decoder: English (AAC LC, 2.0 ch) (track 2, id 0x2)
[03:38:19]      + samplerate: 48000 Hz
[03:38:19]    + AAC Passthru
[03:38:19]  * audio track 2
[03:38:19]    + decoder: ??? (E-AC3, 5.1 ch, 256 kbps) (track 4, id 0x4)
[03:38:19]      + bitrate: 256 kbps, samplerate: 48000 Hz
[03:38:19]    + E-AC3 Passthru
[03:38:19] sync: expecting 34609 video frames
[03:38:19] encavcodecInit: H.265 (AMD VCE)
[03:38:19] encavcodec: encoding at rc=vbr_peak Bitrate 1450
[03:38:19] encavcodec: encoding with stored aspect 1/1
[03:38:19] sync: first pts video is 0
[03:38:19] sync: "Intro" (1) at frame 1 time 0
[03:38:19] sync: first pts audio 0x2 is 0
[03:38:19] sync: first pts audio 0x4 is 0
[03:38:20] sync: first pts subtitle 0x5 is 262440
[03:38:20] sync: "Scene 1" (2) at frame 304 time 1136250
[03:38:20] sync: first pts subtitle 0xb is 1800000
not the answer you want but the best encoder is going to be the quicksync on the UHD 770 that is on 12th gen+ Intel CPU’s (not yours though as it has no iGPU)
The NVencode and the Cuda is for Nvidia cards but it appeared that you did select the AMD encoder
I sadly went away from MCBuddy as I have thousands of files I wanted to convert and it just didnt handle it well. I use Tdarr now.
That UHD 770 using the quicksync is no joke though, runs circles around nvidia encoder/decoder which runs circles around the AMD cards. AMD has never been known to have good encode/decoders and sadly most software just trails behind in proper support.
What software would you recommend I use to take advantage of my GPU for encoding as it doesn’t seem to play nice with Handbrake? I have managed to get a couple of encodes to finish but sadly nothing consistent. Only 1 out of 10 encodes make it past 90%. I did see that with the AMD VCE setting I averaged 400fps during conversion when successful!
I’m assuming you’re having the same issue with the latest handbrake build also. If so, try changing the profile you’re using in MCEBuddy to use ffmpeg instead of handbrake
order=ffmpeg
If the latest version of handbrake is working for you then just download the latest version ofte handbrake CLI exe file and drop it on to the handbrake directory where MCEBuddy is installed.
I would use cheapest Intel ARC card you can find for encoding. No driver issues for me or failed encodings.
Intel 12600k
Intel ARC A380
Teamgroup 16 GB
H.265 quicksync encoding comparable to AV1 in size and quality.
