MCEBuddy running fine. Upgraded to a new nVidia 2060. No HW encoding love. What am I missing?
INFORMATION> 2020-10-28T23:23:08 MCEBuddy.Transcode.Convert --> Converting with Handbrake, type: HardwareOnly, gpu: {
“hardwareBrand”: “NVidia”, “codecType”: “Encoder”,
“hardwareCodecPresent”: true, “h265Codec”: true, “h264Codec”: true
INFORMATION> 2020-10-28T23:23:08 MCEBuddy.Transcode.ConvertWithHandbrake
–> Setting up General conversion parameters : --decomb --loose-anamorphic --verbose=2
–> Setting up PreDRC
–> Setting up input file name parameters
–> Setting up video conversion parameters : --start-at duration:0 -e x265 --encoder-preset medium -q 26
–> Is preset video size -> False
–> Setting up crop parameters
–> Handbrake auto video cropping
–> Checking if video resizing required
–> Setting up aspect ratio if required
–> Setting up bitrate and quality parameters
–> Setting up audio conversion parameters : -E ffac3 -R auto -B 256 -D 0 -a 1,2,3,4,5
–> Selecting Audio Track : -1
–> Letting handbrake choose best audio track
WARNING> 2020-10-28T23:23:08 MCEBuddy.Transcode.ConvertWithHandbrake
–> Cannot get Audio and Video stream details, continuing with default Audio Language selection
–> Setting up volume adjustment : 0.4dB
–> Setting up PostDRC
–> Setting up Audio channels
–> Requested to limit Audio Channels to 2
–> Setting up Output filename
–> Replacing user specified parameters
–> Converting the video - Main conversion
ERROR> 2020-10-28T23:28:10 MCEBuddy.AppWrapper.Handbrake
–> Hardware encoding appears to have hung, no progress in the last 300 seconds.
This is likely due to an unstable Graphics Display Driver. Try updating or using a stable Graphics Display Driver.
Terminating process.
ERROR> --> Unrecoverable error encountered. Process likely hung, killing it
ERROR> 2020-10-28T23:28:10 [repeat]
ERROR> 2020-10-28T23:28:11 [repeat]
ERROR> 2020-10-28T23:28:12 [repeat]
ERROR> --> Process hung, killing process
ERROR> 2020-10-28T23:28:12 MCEBuddy.AppWrapper.Handbrake
ERROR> 2020-10-28T23:28:12 MCEBuddy.Transcode.ConvertWithHandbrake --> Handbrake conversion failed
ERROR> 2020-10-28T23:28:12 MCEBuddy.Transcode.ConvertWithHandbrake --> Conversion of video failed
ERROR> 2020-10-28T23:28:12 MCEBuddy.Transcode.Convert --> Handbrake did not convert successfully, using fallback if configured
INFORMATION> 2020-10-28T23:28:12 MCEBuddy.Transcode.ConvertWithFfmpeg --> Checking for Unsupported profile for container / codec combination
INFORMATION> 2020-10-28T23:28:12 MCEBuddy.Transcode.Convert --> Converting with FFMpeg, type: HardwareOnly, gpu: {
“h265Codec”: true,
“h264Codec”: true
INFORMATION> 2020-10-28T23:28:12 MCEBuddy.Transcode.ConvertWithFfmpeg --> Setting up General conversion parameters : -threads 0
–> Setting up video conversion parameters : -ss 0 -vf yadif=0:-1:1,hqdn3d -vcodec libx265 -preset medium -crf 26 -map 0:v -sn
INFORMATION> 2020-10-28T23:28:12 MCEBuddy.VideoProperties.VideoInfo --> Getting crop information using FFMpeg
WARNING> --> FFMpeg Crop Detect Process Error - retrying with MEncoder
ERROR> --> No response from process for 300 seconds, process likely hung - killing it
WARNING> --> MEncoder Crop Detect Process Error - cropping will not take place
INFORMATION> 2020-10-28T23:34:52 MCEBuddy.Transcode.ConvertWithFfmpeg
–> FFMpeg found no video cropping
–> Setting up audio conversion parameters : -acodec ac3 -ab 256k -map 0:a
–> Letting ffmpeg choose best audio track
–> Cannot get Audio stream details, continuing with default Audio Language selection
WARNING> --> Ffmpeg conversion failed, retying using GenPts
WARNING> 2020-10-28T23:48:48 MCEBuddy.Transcode.ConvertWithFfmpeg --> Ffmpeg conversion failed with hardware decoder, retrying with without hardare decoder
The conversion then proceeds, but no HW speedup since it’s reverting back to CPU encoding.
Any hints on what to look for when I turn up the log details?
