I actually figured out that there was a new version of Playon that seemed to fix the missing metadata. However, now I have a new problem. For example, I’m recording the 2014 version of the flash, but it keeps renaming them to the 1990 version. I’ll attach a log file for one of them. I’m not sure what I’m looking for to know why that’s happening. The Flash - s01e11 The Sound and the Fury.mp4-Convert to M4V-2018-12-25T17-03-13.1654014-06-00.log (878.4 KB)
Your filename is using asymmetrical naming, there’s a - after the title but not after the S/E. @Goose can you look into this and see if we can find a long term solution?
It appears to be matching with an older 1990 version of Flash because TVDB doesn’t seem to have the latest version
Fixed, try today’s 2.4.10 BETA build and see if it fixes your issue. Now it should be able to read asymmetrical - in the filenames while extracting metadata. This only applies to the - character.
This appears to have fixed the flash. I do have issues with other shows where the logs say it can’t find the premiereyear, but then names the show like this. Showname (year) (). Not the end of my world but still strange.
Just curious how much of the file renaming is based on the source file name versus the metadata in the file? I’m getting lots of errors if they aren’t named right to begin with.
There is an priority order that is used to determine which one takes preference if there are multiple sources of metadata, assuming that user provided metadata has the highest priority:
External metadata files (NFO, XML, ARG etc)
Filenames
Embedded metadata
Internet matching (most fills gaps unless the override option is enabled in the Conversion task Metadata correction page)
I found that I had to go into that correction page and fix it there. Then it started working on this one particular show.
On another note, when I record my shows, some shows have commercials while others don’t. Since they all get recorded to the same location that I monitor, they all get run through the conversion with the commercial skip. I’ve found on the shows that don’t have commercials to begin with, that sometimes parts of the shows get cut out as though it thinks there was a commercial. Is there a good way around that other than to have to put in new conversion task for each show?
