Donator comskip 0.80.038 has command line argument change preventing commercial detection
Corrected by actually reading the logs and with comskip82_003_donators
BUG
MCEBuddy 2.4.8 64bit - 20180112
Windows 10 Pro 64 bit
comskip 0.80.038 has had a command line argument change. It no longer requires the --output switch
2018-01-18T20:23:15 MCEBuddy.AppWrapper.Comskip → “C:\Program Files\MCEBuddy2x\comskip\comskip.exe” --output=F:\mcetemp\working0 “F:\mcetemp\working0\The Big Bang Theory - s10e13 - The Romance Recalibration.ts”
2018-01-18T20:23:15 MCEBuddy.AppWrapper.Comskip → Usage:
2018-01-18T20:23:15 MCEBuddy.AppWrapper.Comskip → comskip [-h|–help] [-w|–debugwindow] [-n|–playnice] [–zpcut] [–zpchapter] [–videoredo] [–csvout] [–plist] [-m|–demux] [-p|–pid=] [-t|–ts] [-d|–detectmethod=] [-v|–verbose=] [-u|–dump=] [-s|–play] [-q|–quiet] [–ini=] [–logo=] [–cut=] []
2018-01-18T20:23:15 MCEBuddy.AppWrapper.Comskip → -h, --help Display syntax
2018-01-18T20:23:15 MCEBuddy.AppWrapper.Comskip → -w, --debugwindow Show debug window
2018-01-18T20:23:15 MCEBuddy.AppWrapper.Comskip → -n, --playnice Slows detection down
2018-01-18T20:23:15 MCEBuddy.AppWrapper.Comskip → --zpcut Outputs a ZoomPlayer cutlist
2018-01-18T20:23:15 MCEBuddy.AppWrapper.Comskip → --zpchapter Outputs a ZoomPlayer chapter file
2018-01-18T20:23:15 MCEBuddy.AppWrapper.Comskip → --videoredo Outputs a VideoRedo cutlist
2018-01-18T20:23:15 MCEBuddy.AppWrapper.Comskip → --csvout Outputs a csv of the frame array
2018-01-18T20:23:15 MCEBuddy.AppWrapper.Comskip → --plist Outputs a mac-style plist for addition to an EyeTV archive as the ‘markers’ property
2018-01-18T20:23:15 MCEBuddy.AppWrapper.Comskip → -m, --demux Demux the input into elementary streams
2018-01-18T20:23:15 MCEBuddy.AppWrapper.Comskip → -p, --pid= The PID of the video in the TS
2018-01-18T20:23:15 MCEBuddy.AppWrapper.Comskip → -t, --ts The input file is a Transport Stream
2018-01-18T20:23:15 MCEBuddy.AppWrapper.Comskip → -d, --detectmethod= An integer sum of the detection methods to use
2018-01-18T20:23:15 MCEBuddy.AppWrapper.Comskip → -v, --verbose= Verbose level
2018-01-18T20:23:15 MCEBuddy.AppWrapper.Comskip → -u, --dump= Dump the cutscene at this frame number
2018-01-18T20:23:15 MCEBuddy.AppWrapper.Comskip → -s, --play Play the video
2018-01-18T20:23:15 MCEBuddy.AppWrapper.Comskip → -q, --quiet Not output logging to the console window
2018-01-18T20:23:15 MCEBuddy.AppWrapper.Comskip → --ini= Ini file to use
2018-01-18T20:23:15 MCEBuddy.AppWrapper.Comskip → --logo= Logo file to use
2018-01-18T20:23:15 MCEBuddy.AppWrapper.Comskip → --cut= CutScene file to use
2018-01-18T20:23:15 MCEBuddy.AppWrapper.Comskip → Input file
2018-01-18T20:23:15 MCEBuddy.AppWrapper.Comskip → Output directory
Use the newest version of comskip donator
Convert to MP4-2018-01-18T20-22-45.5899081-05-00.zip (35.1 KB)
Solved in post 1 - update to latest version of Comskip 0.82.xx or newer.
