Cut Start with Ad Markers causes segment of show before ad to get cut
Request Type:
BUG
MCEBuddy 2.4 Beta 9 *26 Oct 2018) 64bit
Windows 10 64bit
Using PlayLater captures from CBS with a Cut Start of 5 seconds and a Cut End of 5 seconds I noticed that about 5 seconds before an Ad marker the show segment is cut off. I am doing MP4 from PlayLater and converting to MKV Unprocessed.
I assume this is due to a frame offset when determine what to cut.
Steps to replicate the bug:
Set cut start and cut end to 5 seconds. Convert an mp4 file generated by PlayLater that contain ad markers using the MKV Unprocessed Profile.
Full settings are in attached logs
YoungSheldon_0206.7z (33.7 KB)
Thanks for reporting this, MCEBuddy would under certain conditions “double” adjust the commercial cuts starting point when a Cut start value was specified.
This has been fixed in today’s 2.4.9 build.
Fix worked perfectly. Thank you for the fast resolution.
