The Raw files will open in VLC just fine.
But when I convert the files using MKV it will show the correct length and the correct file size in windows explorer but will not play at all.
Check your installed codecs, they may be corrupted or not compatible. We only recommend using the included Haali Media Splitter codec for windows or FFDShow. Try it on a different computer.
thanks…I had to switch off the hardware acceleration and it worked fine…is there a previous version where acceleration works better?
Hardware encoding isn’t done by MCEBuddy, it is handled by the graphics driver. See the FAQ’s and similar topics about hardware encoding. It’s a defective graphics driver.
