Comskip not working since upgrade to 2,71
I have not been able to get comskip to work consistently. I realize it never works 100%, but it is no longer working at all, at least for some recordings. Here are two recordings back to back. One worked and the other did not
CBS.News.Sunday.Morning.S2026E23.ts-Convert to MP4-2026-06-07T11-58-22.log (2.1 MB)
Sunday Morning Maine_2026-06-07_07000900.ts-Convert to MP4-2026-06-07T11-31-00.log (2.1 MB)
I’m seeing it detect and successfully cut a bunch of commercials. Are you seeing additional commercials ?
2026-06-07T12:01:50 MCEBuddy.AppWrapper.Comskip → Commercials were found.
→ Process exited with code 1
2026-06-07T12:01:52 MCEBuddy.CommercialScan.Scanner → Commercial Scan: Percentage Complete 99
INFORMATION> 2026-06-07T12:01:52 MCEBuddy.CommercialScan.Scanner → Using EDL file for commercial removal
2026-06-07T12:01:52 MCEBuddy.CommercialScan.Scanner → Testing EDL File Validity
2026-06-07T12:01:52 MCEBuddy.CommercialScan.Scanner → ParseEDL: Cut Segment Start:0.000 End:10.980 Action:0
2026-06-07T12:01:52 MCEBuddy.CommercialScan.Scanner → ParseEDL: Cut Segment Start:261.860 End:436.400 Action:0
2026-06-07T12:01:52 MCEBuddy.CommercialScan.Scanner → ParseEDL: Cut Segment Start:917.950 End:1009.710 Action:0
2026-06-07T12:01:52 MCEBuddy.CommercialScan.Scanner → ParseEDL: Cut Segment Start:1051.120 End:1173.040 Action:0
2026-06-07T12:01:52 MCEBuddy.CommercialScan.Scanner → ParseEDL: Cut Segment Start:1641.570 End:1728.390 Action:0
2026-06-07T12:01:52 MCEBuddy.CommercialScan.Scanner → ParseEDL: Cut Segment Start:2036.830 End:2166.760 Action:0
2026-06-07T12:01:52 MCEBuddy.CommercialScan.Scanner → ParseEDL: Cut Segment Start:2313.810 End:2465.960 Action:0
2026-06-07T12:01:52 MCEBuddy.CommercialScan.Scanner → ParseEDL: Cut Segment Start:2491.660 End:2653.520 Action:0
2026-06-07T12:01:52 MCEBuddy.CommercialScan.Scanner → ParseEDL: Cut Segment Start:3134.060 End:3249.550 Action:0
2026-06-07T12:01:52 MCEBuddy.CommercialScan.Scanner → ParseEDL: Cut Segment Start:3788.820 End:3935.800 Action:0
2026-06-07T12:01:52 MCEBuddy.CommercialScan.Scanner → ParseEDL: Cut Segment Start:4260.490 End:4382.240 Action:0
2026-06-07T12:01:52 MCEBuddy.CommercialScan.Scanner → ParseEDL: Cut Segment Start:4405.600 End:4542.640 Action:0
2026-06-07T12:01:52 MCEBuddy.CommercialScan.Scanner → ParseEDL: Cut Segment Start:5010.270 End:5147.110 Action:0
2026-06-07T12:01:52 MCEBuddy.CommercialScan.Scanner → ParseEDL: Cut Segment Start:5230.790 End:5403.260 Action:0
→ ConvertCutListToKeepList: Skip initial segment, too small Start:0.000 Stop:0.000
→ ConvertCutListToKeepList: Keep segment Start:10.980 Stop:261.860
→ ConvertCutListToKeepList: Keep segment Start:436.400 Stop:917.950
→ ConvertCutListToKeepList: Keep segment Start:1009.710 Stop:1051.120
→ ConvertCutListToKeepList: Keep segment Start:1173.040 Stop:1641.570
→ ConvertCutListToKeepList: Keep segment Start:1728.390 Stop:2036.830
→ ConvertCutListToKeepList: Keep segment Start:2166.760 Stop:2313.810
→ ConvertCutListToKeepList: Keep segment Start:2465.960 Stop:2491.660
→ ConvertCutListToKeepList: Keep segment Start:2653.520 Stop:3134.060
→ ConvertCutListToKeepList: Keep segment Start:3249.550 Stop:3788.820
→ ConvertCutListToKeepList: Keep segment Start:3935.800 Stop:4260.490
→ ConvertCutListToKeepList: Keep segment Start:4382.240 Stop:4405.600
→ ConvertCutListToKeepList: Keep segment Start:4542.640 Stop:5010.270
→ ConvertCutListToKeepList: Keep segment Start:5147.110 Stop:5230.790
→ ConvertCutListToKeepList: Keep end segment Start:5403.260 Stop:5404.556
It was two programs recorded weekly. A couple of times one program did not detect or at lest cut, any commercials. Then all of a sudden it started working again. Sorry for false alarm.
Comskip 2.7.1 not working for me either…
2026-09-20T15:59:07 MCEBuddy.AppWrapper.Comskip → Comskip 0.83.001-20250228, made using ffmpeg
2026-09-20T15:59:07 MCEBuddy.AppWrapper.Comskip → Donator build
→ Process exited with code 2
WARNING> 2026-09-20T15:59:09 MCEBuddy.AppWrapper.Comskip → Comskip failed
INFORMATION> → Comskip version : DONATOR
INFORMATION> → Comskip build : CUSTOM
Please attach the full log and @Forum_Helper_bot can also assist. A few lines don’t share the whole context. There will be a single failure message when MCEBuddy tests which version of Comskip is installed but that doesn’t mean Comskip is failing.
@laffer98 As Goose mentioned, that snippet alone doesn’t necessarily indicate a commercial detection failure. When MCEBuddy initializes Comskip, it first queries the executable to determine whether it is running the free or donator version, which routinely triggers a benign failure/exit code during version detection.
To pinpoint what is actually happening when Comskip runs against your video file, please upload your full conversion log (you can find it in your log directory or attach the .log file directly to your reply).
