No longer detecting commercials
I loaded the trial version on a new computer, and still have it on my old computer. The new computer died after I loaded the MCE Buddy and so far I haven’t been able to get the new pc to boot. Going back to the old computer, commercial skipping isn’t working anymore, did’t change any settings. If I end up having to reset or reload windows on the new PC, am I now stuck with no commercial skipping regardless of what happens? Please advise.
If it was working but then stopped it could be because either the settings have changed or the content has changed and the commercial detection settings need a tweak.
Start by attaching your conversion log so we can see what’s going on.
The Voice_20251103_20002200.ts-Convert to MP4-2025-11-03T22-06-34.log (3.6 MB)
Tracker_20251102_20002300.ts-Convert to MP4-2025-11-02T23-03-11.log (3.7 MB)
The Voice recording 11-3 did not skip commercials
The Tracker recording 11-2 did skip commercials
Thanks for any help !
According to the logs it found commercials.
2025-11-03T22:17:19 MCEBuddy.AppWrapper.Comskip → Commercials were found.
→ Process exited with code 1
2025-11-03T22:17:21 MCEBuddy.CommercialScan.Scanner → Commercial Scan: Percentage Complete 99
INFORMATION> 2025-11-03T22:17:21 MCEBuddy.CommercialScan.Scanner → Using EDL file for commercial removal
2025-11-03T22:17:21 MCEBuddy.CommercialScan.Scanner → Testing EDL File Validity
2025-11-03T22:17:21 MCEBuddy.CommercialScan.Scanner → ParseEDL: Cut Segment Start:1185.420 End:1215.510 Action:0
2025-11-03T22:17:21 MCEBuddy.CommercialScan.Scanner → ParseEDL: Cut Segment Start:1498.200 End:1533.500 Action:0
2025-11-03T22:17:21 MCEBuddy.CommercialScan.Scanner → ParseEDL: Cut Segment Start:2432.460 End:2462.730 Action:0
2025-11-03T22:17:21 MCEBuddy.CommercialScan.Scanner → ParseEDL: Cut Segment Start:2827.820 End:3008.710 Action:0
2025-11-03T22:17:21 MCEBuddy.CommercialScan.Scanner → ParseEDL: Cut Segment Start:4348.710 End:4544.670 Action:0
2025-11-03T22:17:21 MCEBuddy.CommercialScan.Scanner → ParseEDL: Cut Segment Start:4856.890 End:4952.750 Action:0
2025-11-03T22:17:21 MCEBuddy.CommercialScan.Scanner → ParseEDL: Cut Segment Start:5997.730 End:6026.420 Action:0
2025-11-03T22:17:21 MCEBuddy.CommercialScan.Scanner → ParseEDL: Cut Segment Start:6153.280 End:6228.620 Action:0
2025-11-03T22:17:21 MCEBuddy.CommercialScan.Scanner → ParseEDL: Cut Segment Start:7285.280 End:7492.890 Action:0
→ ConvertCutListToKeepList: Keep segment Start:0.000 Stop:1185.420
→ ConvertCutListToKeepList: Keep segment Start:1215.510 Stop:1498.200
→ ConvertCutListToKeepList: Keep segment Start:1533.500 Stop:2432.460
→ ConvertCutListToKeepList: Keep segment Start:2462.730 Stop:2827.820
→ ConvertCutListToKeepList: Keep segment Start:3008.710 Stop:4348.710
→ ConvertCutListToKeepList: Keep segment Start:4544.670 Stop:4856.890
→ ConvertCutListToKeepList: Keep segment Start:4952.750 Stop:5997.730
→ ConvertCutListToKeepList: Keep segment Start:6026.420 Stop:6153.280
→ ConvertCutListToKeepList: Keep segment Start:6228.620 Stop:7285.280
→ ConvertCutListToKeepList: Keep end segment Start:7492.890 Stop:7494.228
→ ConvertKeepListToCutList: Skip segment, too small Start:0.000 Stop:0.000
→ ConvertKeepListToCutList: Cut segment Start:1185.420 Stop:1215.510
→ ConvertKeepListToCutList: Cut segment Start:1498.200 Stop:1533.500
→ ConvertKeepListToCutList: Cut segment Start:2432.460 Stop:2462.730
→ ConvertKeepListToCutList: Cut segment Start:2827.820 Stop:3008.710
→ ConvertKeepListToCutList: Cut segment Start:4348.710 Stop:4544.670
→ ConvertKeepListToCutList: Cut segment Start:4856.890 Stop:4952.750
→ ConvertKeepListToCutList: Cut segment Start:5997.730 Stop:6026.420
→ ConvertKeepListToCutList: Cut segment Start:6153.280 Stop:6228.620
→ ConvertKeepListToCutList: Cut segment Start:7285.280 Stop:7492.890
→ ConvertKeepListToCutList: Skip end segment, too small Start:7494.228 Stop:7494.228
→ ConvertKeepListToCutList Done
The original file was 7494 seconds and after cutting commercial it was 6619 seconds.
Looks like it’s finding and cutting commercials according to the voice logs.
