Premium version available via Premium Access Program
Trial version is available here
Changelog for 2.6.2 (64bit)
NEW FEATURES:
- Option to automatically download and install the OCR add-on files required to convert image based subtitles to text based subtitles.
- Added support for reading chapter files (MKV, MP4, XML, OGG, VTT, etc)
- Added support for processing embedded and external subtitles including SubRip (.srt), WebVTT (.vtt), Timed Text (.ttxt), YouTube (.xml), SubStationAlpha (.ass), DVB Teletext, Closed captions etc
- When only marking ads, the embedded chapters now contains the Advertisement chapter makers and Video chapter makers
- Show engine name in system tray icon status when connected to a remote engine
- Added support for AV1 hardware encoding for Intel, NVidia and AMD
- Added support for AV1 codec filter in metadata selection
- Added AV1 profiles
- Added option to force metadata lookup by Episode name, Season/Episode No or Original air date under Conversion task → Expert settings → Metadata corrections
- Upgrade to newer versions without uninstalling older versions of MCEBuddy starting 2.6.2 (2.6.1 or older must be uninstalled before installing 2.6.2)
BUG FIXES:
- Fixed UI inconsistencies
- Fixed an issue with some log files not opening from the History page
- Fixed an issue with incorrect chapter markers causing video playback issues due to incorrect duration
- Fixed issue with 2 pass encoding when using ffmpeg
- HEVC MP4 profile renamed to MP4 HEVC to standardize naming formats (similarly for MKV & other HEVC profile)
- Fixed a bug with E-AC3 audio volume leveling
- Fixed issue with handbrake not selecting best audio track
- Fixed issue with not being able to process readonly EDL files
- Fixed issue with commercials being cut twice causing programs to be cut accidentally
ENHANCEMENTS:
- Updated documentation
- Added more language translations (130+)
- Subtitle extraction is enabled by default, added an option to Save subtitles to disk
- Improve metadata extraction from MP4 files to support more format from Playlater, MetaX, TVMosaic and more
- Automatically uninstall old version of MCEBuddy when trying to install a newer build (still recommended to manually uninstall old version)
- Now compatible with ffmpeg to 6.1
- Now compatible with handbrake to 1.7.2
- Retaining support for hardware encoding for older Intel chipsets starting with Sandy Bridge when using handbrake and ffmpeg
- Improved quality of AMD AMF hardware encoding
- Optimized video cropping and don’t overwrite profile crop parameters if present
- Reduce conversion time by reordering commercial cutting
