NOTE: For ongoing support & development, starting major version 2.6.1, access to new releases (STABLE & BETA) will require a new license (those purchased on or after January 18th 2023)
Refer to 2.5.7 release notes for more details about legacy licenses.
Premium version available via Premium Access Program
Trial version is available here
Changelog for 2.6.1 (64bit)
NEW FEATURES:
- Added support for Windows 11
- Added support for extracting ad markers from cTiVO MP4 recordings
- Added options to specify custom cli parameters for Comskip in Conversion Tasks → Expert Settings
BUG FIXES:
- Fix for identifying MP4 episode metadata (Streamfab and iTunes)
- Fix >10 metadata correction entries caused UI problems
- Fix for broken internet metadata matching and updates
- Fix for conversions failing when processing a read only file
- Improve detection and correction of IMDB id from metadata
- Fix IMDB metadata
ENHANCEMENTS:
- Fix for validating network paths
- Added support for 10K and 16K max resolution
- Use Alt + N to add new metadata correction row entry
- Added support for Basque, Faroese and Galician language translations
- Show network credential warning once per network path when adding files manually. Warnings are reset when MCEBuddy is closed or minimized
- Improve series premiere date (series air date) matching with TVDB
- Report status of
rescancommand when sent via CLI - Updated base libraries, security and stability
- Allow for manual metadata corrections without downloading
- Improve pop up help on how to use regex to match and replace titles in manual metadata correction
- Added
%imdbmovieid%- IMDb Movie ID,%movieid%- TMDB Movie ID,%seriesid%- TVDB Series ID patterns to custom renaming options - Improved the CommandLine Engine status display to sync with the GUI
- Added support for 18 new language translations (total 129 languages)
- Speed up IMDB metadata for long running shows
