NOTE: To continue supporting development, 2.5.x will be last major release update available to legacy license holders (those purchased before January 18th 2023). Users with legacy licenses can continue to use and download legacy versions of MCEBuddy (up to 2.5.x)
Access to updates starting major version 2.6.x will require a new license (those purchased on or after January 18th 2023)
Premium version available through the Premium Access Program
Trial version is available here
Changelog for 2.5.7 (64bit)
NEW FEATURES:
- Added support for Streamfab metadata
- Double click on item in conversion queue to open file in folder
- Added pop up list of metadata variables for Custom renaming patterns while typing
- 116 language translations
- Added ability detect and retain qualifiers (cc, forced, sdh etc) in .SRT subtitles
BUG FIXES:
- Check for empty files (0 bytes) before processing them
- Fix for endless re-conversions if destination directory name ends with a
. - Fix where converted files are reconverted again leading to a potential infinite conversion loop when the system is under heavy stress
- Fix downscaling when using ffmpeg profiles and hardware encoding fails
- Allow Ctrl+V for TVDB Id in metadata corrections
- Allow Season 0 in custom renaming pattern
- Fix IMDB metadata
- Fix issue with QSV hardware encoding when using HEVC profiles and unsupported presets
ENHANCEMENTS:
- Optimize IMDB to reduce traffic and speed up metadata matching
- Handle malformed SRT and IDX subtitle files better
- Extracting dvbsub subtitles from MP4 files (OCR requires Tessdata)
- Updated ccextractor to 0.93
- TV.com is defunct, remove it to save time
- Create apple compatible H.265 video profiles (use hvc1 instead of hev1)
- Improve metadata matching logic for more accurate matches
- Update filenames format to be more compatible with Plex for improved subtitle matching
