2.6.5 Release Notes
Premium version available via Premium Access Program
Trial version is available here
Changelog for 2.6.5 (64bit)
NEW FEATURES:
  • Display the metadata for any file directly from Windows Explorer by right clicking on the file and selecting Show media info with MCEBuddy or by selecting multiple media files, right click and select Send To → Get media info with MCEBuddy
  • The Monitor locations and Conversion tasks split pane is now height adjustable
BUG FIXES:
  • Improve detection of scan type
  • Fix failure to detect video corruption while cutting commercials leading to converted file with partial commercials cut out. Now try to fix corruption and retry cutting or fail conversion
  • Fix issue with WTV h.264 encoding where some converted videos do not play back in WMC/WMP
  • Fix for invalid directory name created in some cases when metadata ends with a space
  • Fix for UI crash when GPU selection is enabled and hardware is changed without updating the GPU selection
ENHANCEMENTS:
  • Allow for matching filters against empty strings using regex: patterns
  • When duplicating or renaming a task, use the name of the original task name as the starting point
  • When moving tasks don’t lose focus on the selected task
  • Requires Windows 10 and above (ffmpeg7 and handbrake requirements)
  • Updated to ffmpeg7, remuxing upto 3x faster
  • Updated LAVFilter to 0.79.2 for improved H/W decoding support and more codecs
  • Updated Comskip to 0.83.001 and ffmpeg7 with optimized build for MCEBuddy with hardware decoding
  • Improve layout to reduce dead space and enhance usability
  • Added option to get list and status of conversions in queue from the CLI MCEBuddy.UserCLI --command=query --action=queue
  • Added support for NVidia and AMD hardware AV1 decoding for custom Comskip
  • Configure custom comskip hardware accelerated decoding under Conversion task → Expert settings → Comskip options →
    • Intel QSV (–qsv)
    • NVidia CUVID (–cuvid)
    • AMD AMF/VCE (–dxva2)
This topic was automatically closed after 4 days. New replies are no longer allowed.
