Out of about 120 remuxing jobs WTV->TS one file can’t be completed correctly during a couple of tries.
The WTV comes with 3 audio tracks; the log shows that they are detected correctly by ffprobe BEFORE remuxing and also AFTER remuxing;
actually after remuxing a process directive says --> Checking for 0 Channel Audio Tracks in...
after which an ffprobe instance is started and it lists all audio tracks in the TS file correctly; directly after that the following messages appear in the log:
WARNING> --> Found 0 channel audio track in file...
INFORMATION> ... Found 0 channel audio while remuxing, re-remuxing using a single audio track
If you look at the logs, while remuxing ffmpeg seems to encounter issues with the audio and video streams. So when it’s complete one of the audio tracks (deu) is not identified properly and shows up with any audio channels. So MCEBuddy skips it otherwise the conversion will fail downstream.
Basically the recording device created a non compliant stream.
–> [mpeg2video @ 000001fc5f1b1060] Invalid frame dimensions 0x0.
2018-03-26T17:18:09 MCEBuddy.AppWrapper.FFmpeg --> Last message repeated 1 times
2018-03-26T17:18:09 MCEBuddy.AppWrapper.FFmpeg --> [wtv @ 000001fc5f14ae60] Stream #5: not enough frames to estimate rate; consider increasing probesize
2018-03-26T17:18:09 MCEBuddy.AppWrapper.FFmpeg --> Guessed Channel Layout for Input Stream #0.2 : stereo
I noticed some of those messages and wasn’t quite sure of their meaning-
mainly because in other places I see that ffprobe seems to perfectly recognize the streams-
I’ll see if I can get a remux via VLC (plays all audio streams w/o issues)-
