No Sound trying to use copy audio ffmpeg
Hi,
I am trying to just copy audio in my conversions but I get no sound? can someone please look at my profile and log? Thank you
[My HEVC MKV]
Description=My HEVC in MKV My Custom HEVC Settings.
order=ffmpeg
ffmpeg-general=-threads 0
ffmpeg-video=-ss 0 -vf yadif=0:-1:1,hqdn3d -vcodec libx265 -preset medium -crf 21 -map 0:v -sn
ffmpeg-audio=-acodec copy
ffmpeg-ext=.mkv
ffmpeg-audiodelay=skip
mcqueen.2018.limited.720p.b.mkv-My HEVC MKV-2018-10-26T12-21-03.9621750 01-00.log (1.8 MB)
ok, I saw there was no stream selected & this works for AC3 (it just copies the stream) but how do I get the same for DTS? if the video has DTS there is no Audio in the processed file?
[My HEVC MKV]
order=ffmpeg
ffmpeg-audio=-acodec ac3 -ab 320k -map 0:a
ffmpeg-audioac3=-acodec ac3 -ab 320k -map 0:a
ffmpeg-ext=.mkv
handbrake-general=–decomb --loose-anamorphic --verbose=2
handbrake-video= -e x265 --encoder-preset medium -q 21
handbrake-audio=-E ffac3 -R auto -B 320 -D 0 -a 1,2,3,4,5
handbrake-audioac3=-E ffac3 -R auto -B 320 -D 0 -a 1,2,3,4,5
handbrake-ext=.mkv
handbrake-audiodelay=skip
PreConversionCommercialRemover=false
Did you notice that you’re repeating lines in your profile making it ambiguous?
What you should be doing in just replace -ac3 with -copy and remove the -ab, so it should look like:
ffmpeg-audio=-acodec copy -map 0:a
Refer to the Profiles Basics topic for details on how profile commands work.
Hi, Thanks so much for your reply and yes I can see it now! (sorry) I have amended my profile to the following but I get a conversion failure? also will these copy all streams? (FLAC, AC3, DTS etc)
Thanks Again!!
[My HEVC MKV]
order=ffmpeg
ffmpeg-ext=.mkv
handbrake-ext=.mkv
The Ant Bully (2006).mkv-My HEVC MKV-2018-10-26T14-51-09.1064012 01-00.log (1.5 MB)
mcqueen.2018.limited.720p.mkv-My HEVC MKV-2018-10-26T14-51-09.1343263 01-00.log (1.7 MB)
Looks like ffmpeg is choking on your audio while trying to copy it, it’s a known open defect in ffmpeg.
Meanwhile add -max_muxing_queue_size 4000 to your ffmpeg-video line it should fix the issue.
ffmpeg-video=-ss 0 -max_muxing_queue_size 4000 -vf yadif=0:-1:1,hqdn3d -vcodec libx265 -preset medium -crf 21 -map 0:v -sn
If that still fails, try increasing 4000 to 99999
You can also remove the handbrake-xxx lines since you aren’t using handbrake
We’ll try to put in a detection for this error and automatic correction in the next build of mcebuddy
EDIT: Cross reference: Ffmpeg Bug - Too many packets buffered for output stream
Can you upload a copy of the original recording to our server so we can analyze it and put patch for it.
See this topic for instructions on how to upload.
This has been handled in today’s 2.4.9 BETA build. You can try it out.
