Some disappointing news, MCEBuddy fans using the new Handbrake 1.7.1 in the MCEBuddy 2.6.2 beta.
Looks like we are going to need to upgrade Handbrake to 1.7.2 (GitHub) sooner rather than later. i.e. Manually replace MCEBuddy’s Handbrake CLI binary (and ‘hb.dll’ because on GitHub it is not linked into the main CLI binary like it is in MCEBuddy) if you need the fixes before they get merged into a future beta.
I have experienced the issue with NVENC and VP9/AV1 encoding that creates unusually smaller files that have unreasonably long durations. As in transcoding a 2 minute video and it looks a little small, but the run time says the AV1 version is almost 2 hours long. This is how the “inserting excessive key frames” bug noted below manifests itself. That is in addition to fixing (on Windows) not using the new NVDEC (GPU decode) feature that was just added.
Defects fixed in Handbrake 1.7.2 (from the Handbrake 1.7.1 currently included in MCEBuddy 2.6.2 20231221 beta):
Video
Improved automatic selection of Dolby Vision Level
Fixed an issue in AMD VCN, MPEG-2, MPEG-4, NVIDIA NVENC, and VP9 encoders that could cause the creation of an excessive number of keyframes (#5530)
Fixed unintentional automatic pass through of closed caption side data when using NVIDIA NVENC encoder
Miscellaneous bug fixes and improvements
Linux
Improved performance by removing duplicate graphic assets and reducing file size
Fixed Flatpak file chooser opening home directory instead of the previously selected directory
Fixed last item in the queue sometimes having the wrong destination path
Fixed some memory leaks in the graphical interface
Mac
Added a workaround to prevent a system crash when using VideoToolbox encoders with macOS 14 Sonoma on Apple Silicon Ultra
Added a workaround to prevent issues decoding H.264 video by disabling VideoToolbox hardware decoding for Level 6.1 and 6.2
Fixed a crash opening an empty folder
Windows
Added Automation Properties to some controls on the audio tab to assist screen readers
Looks like Goose has been a busy elf!
The Handbrake 1.7.2 release is in the 20231225 build of MCEBuddy 2.6.2 beta.
Also note that you only need to include the “hb.dll” with the CLI binary if you are using the Nightly builds. It is included in the main release builds.
To add some context to techpro2004’s request to include AC-4 codecs in the FFmpeg (and the one baked into the handbrake) binaries used by MCEBuddy, AC-4 is the name for the Dolby Atmos codec, and more importantly, it is an audio codec used in ATSC3 broadcasts. So with increasing numbers of people using ATSC3 tuners with DVRs, we are likely to see more folks using MCEBuddy to end up with processed video with no audio since the FFmpeg can’t decode the AC-4 audio in the native ATSC3 streams.
The ask is to use this patch in the interim until the FFmpeg devs add AC4 support, which is likely, but there is no timetable and this patch is available.
I don’t have an ATSC3 tuner, but added this for folks wondering.
Looks like there are legal issues with anything AC4 related.
The FCC approved ATSC 3.0 with no open alternative to AC-4, forcing consumers to buy Dolby-licensed hardware just to hear broadcasts.
" It is deeply problematic that ATSC 3.0 mandates a proprietary codec (Dolby AC-4) for audio on free over-the-air (OTA) television in the U.S. and other regions adopting the standard. This effectively locks out open-source software like FFmpeg, VLC, Plex, and Kodi, preventing the public from fully accessing broadcasts that are supposed to be free."
Plex team already said they are not going to support AC4 audio IIRC. So, there will be no way to support anything with AC4 audio in Plex, DVR or just files with AC4 audio.
The core problem is that the ATSC3 for-profit participants will revoke licensing and litigate against anyone making any kind of “transcoder” from AC4 to anything else as it “bypasses” their intentional content extortion scheme backed by the DMCA and patent encumbered standards mandated for public use. So we won’t see transcoding built into DVR devices like HDHR or Tablo, nor anything downstream from a DVR device (like MCE Buddy).
(see Setting the Record Straight on Dolby AC-4 and MPEG-H | SIGNAL )
I know that’s not the answer we want to hear, but I’m not sure I want MCE Buddy to become a target of the broadcast media’s expensive lawyers looking to justify their retainers and make an example in furtherance of privatizing and extorting profit from what was a public resource.
@mike808 silicondust offers a cloud transcoding service for ac4 for client devices that do not support it and use their app. Also the ffmpeg binarys with ac4 support that I posted above are compiled from opensource code available on github. If they are going to go after anyone it would make sense for them to go after that 3rd party ffmpeg github repo. It is a well known repo with links to it all over the internet. Plus that repo has been up for many years with regular updates and no one has done anything to it yet. So if they were going to go after anyone they would have done it by now. I am completely confident that mcebuddy is safe with ac4 support and no legal action will occur (but that is just my opinion).
