TheTVDB matching fails on a forced series ID
WARNING> → No match found on TVDB for language en
WARNING> 2022-12-23T23:16:18 MCEBuddy.MetaData.VideoMetaData → TheTVDB failed
When I looked up the show in TheTVDB, How to Cook Well with Rory O’Connell (Series ID 306346), I thing I saw references to “ENG” (using the 3-letter language code), and not “EN”.
Could there be a disconnect there? I have a rule set in my profiles to force match these shows to the TheTVDB series due to guide differences in the show titles between HDHR and Tivo - miscellaneous commas and “smart” quotes type stuff.
The problem is that the show isn’t matching TheTVDB entries for metadata (per above).
Exception rule in profile:
Show Title match "How to Cook Well*" -> TheTVDB Series 306346
mcebuddy.log:
WARNING> 2022-12-23T23:35:53 MCEBuddy.Engine.QueueManager --> File How to Cook Well At Christmas with Rory O'Connell 20201114 [20221224-0500].mpg did not match Show Type Movie meta data pattern
WARNING> 2022-12-23T23:36:00 MCEBuddy.Engine.QueueManager --> File How to Cook Well At Christmas with Rory O'Connell 20201114 [20221224-0500].mpg did not match Network/Channel meta data pattern
WARNING> 2022-12-23T23:36:06 MCEBuddy.Engine.QueueManager --> File How to Cook Well At Christmas with Rory O'Connell 20201114 [20221224-0500].mpg did not match Show Type Sports meta data pattern
WARNING> 2022-12-23T23:36:19 MCEBuddy.Engine.QueueManager --> File How to Cook Well At Christmas with Rory O'Connell 20201114 [20221224-0500].mpg did not match Network/Channel meta data pattern
WARNING> 2022-12-23T23:36:19 MCEBuddy.Engine.QueueManager --> File How to Cook Well At Christmas with Rory O'Connell 20201114 [20221224-0500].mpg did not match Filename meta data pattern
I’m not able to replicate the issue with the latest 2.4.8 beta. Will need to complete logs to investigate it
