Processing a file with no metadata through a profile specifically to fill in metadata or to merge/overwrite metadata from internet sources (TheTVDB, TMDB, IMDB, etc.)
Media File: The Grinder (2015)-S01E01-Pilot-MP2-720x480-AC3-5.1.mkv
Filename has the series name, start year, Series and Episode in it. Log shows it did not detect 1) that this file is a TV series, and 2) did not pull the metadata from TheTVDB even though there is a clear match from the filename elements.
Note: The conversion failed due to some issue with chapters, but that is a separate issue.
Log Extracts:
INFORMATION> --> Task -> MKV-LastResort-HD
Profile -> MKV AV1
Source File -> E:\Recorded TV\Manual\The Grinder (2015)-S01E01-Pilot-MP2-720x480-AC3-5.1.mkv
Relative Source Path -> E:\Recorded TV\Manual
Destination Path -> E:\Video
Embed Chapters -> True
Strict Processing -> False
Commercial Removal -> Comskip
Download Series Details -> True
Download Banner -> True
Overwrite metata from Title -> False
Overwrite metata from Internet -> Default
Prioritize matching metadata -> AirDate
Force Show Type -> Default
Write Metadata -> True
Rename by Series -> True
Alt Rename by Series -> False
Custom Rename by Series -> %ifseason%<\TV Shows\%showname%\Season %season%##\%showname%-S%season%##E%episode%##-%episodename%-%airyear%-%airmonth%-%airday%-%recordhour%%recordminute%,\Specials\%showname%-%subtitle%-%episodename%-%airyear%-%airmonth%-%airday%-%recordhour%%recordminute%>
Rename Only -> False
INFORMATION> 2026-08-05T10:09:03 MCEBuddy.Engine.ConversionJob --> Checking for disk space
INFORMATION> 2026-08-05T10:09:03 MCEBuddy.Engine.ConversionJob --> Running custom commands
INFORMATION> 2026-08-05T10:09:03 MCEBuddy.Transcode.CustomCommand --> No custom commands found
INFORMATION> 2026-08-05T10:09:03 MCEBuddy.Engine.ConversionJob --> Getting show information and banner from Internet sources
INFORMATION> 2026-08-05T10:09:03 MCEBuddy.MetaData.VideoMetaData --> Extracting Generic Tags
WARNING> --> Error reading metadata from file, possibly corrupted
INFORMATION> 2026-08-05T10:09:03 MCEBuddy.MetaData.VideoMetaData --> Read Tags: MKV file detected using Matroska
WARNING> 2026-08-05T10:09:03 MCEBuddy.MetaData.VideoMetaData --> Unknown MKV tag, Tag:BPS, Value:448000
WARNING> 2026-08-05T10:09:03 MCEBuddy.MetaData.VideoMetaData --> Unknown MKV tag, Tag:DURATION, Value:00:22:57.536000000
WARNING> 2026-08-05T10:09:03 MCEBuddy.MetaData.VideoMetaData --> Unknown MKV tag, Tag:NUMBER_OF_FRAMES, Value:43048
WARNING> 2026-08-05T10:09:03 MCEBuddy.MetaData.VideoMetaData --> Unknown MKV tag, Tag:NUMBER_OF_BYTES, Value:77142016
WARNING> 2026-08-05T10:09:03 MCEBuddy.MetaData.VideoMetaData --> Unknown MKV tag, Tag:SOURCE_ID, Value:0180BD
WARNING> 2026-08-05T10:09:03 MCEBuddy.MetaData.VideoMetaData --> Unknown MKV tag, Tag:_STATISTICS_WRITING_APP, Value:MakeMKV v1.18.4 win(x64-release)
WARNING> 2026-08-05T10:09:03 MCEBuddy.MetaData.VideoMetaData --> Unknown MKV tag, Tag:_STATISTICS_WRITING_DATE_UTC, Value:2026-08-05 14:40:33
WARNING> 2026-08-05T10:09:03 MCEBuddy.MetaData.VideoMetaData --> Unknown MKV tag, Tag:_STATISTICS_TAGS, Value:BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES SOURCE_ID
WARNING> 2026-08-05T10:09:03 MCEBuddy.MetaData.VideoMetaData --> Unknown MKV tag, Tag:BPS, Value:5964782
WARNING> 2026-08-05T10:09:03 MCEBuddy.MetaData.VideoMetaData --> Unknown MKV tag, Tag:DURATION, Value:00:22:57.743033333
WARNING> 2026-08-05T10:09:03 MCEBuddy.MetaData.VideoMetaData --> Unknown MKV tag, Tag:NUMBER_OF_FRAMES, Value:33033
WARNING> 2026-08-05T10:09:03 MCEBuddy.MetaData.VideoMetaData --> Unknown MKV tag, Tag:NUMBER_OF_BYTES, Value:1027242160
WARNING> 2026-08-05T10:09:03 MCEBuddy.MetaData.VideoMetaData --> Unknown MKV tag, Tag:SOURCE_ID, Value:0100E0
INFORMATION> 2026-08-05T10:09:03 MCEBuddy.MetaData.VideoMetaData --> Downloading Series details
INFORMATION> 2026-08-05T10:09:03 MCEBuddy.MetaData.VideoMetaData --> Recording Type Show
INFORMATION> 2026-08-05T10:09:03 MCEBuddy.MetaData.VideoMetaData --> Checking TheTVDB
WARNING> 2026-08-05T10:09:04 MCEBuddy.MetaData.VideoMetaData --> TheTVDB failed
INFORMATION> 2026-08-05T10:09:04 MCEBuddy.MetaData.VideoMetaData --> Checking TMDB
INFORMATION> 2026-08-05T10:09:04 MCEBuddy.Engine.ConversionJob --> Running custom commands
WARNING> --> Cannot find AirYear
WARNING> --> Cannot find AirMonth
WARNING> --> Cannot find AirDay
WARNING> --> Cannot find RecordHour using File Creation Date
WARNING> --> Cannot find RecordMinute using File Creation Date
INFORMATION> 2026-08-05T10:09:04 MCEBuddy.Transcode.CustomCommand --> No custom commands found
INFORMATION> 2026-08-05T10:09:05 MCEBuddy.MetaData.VideoMetaData --> Not checking IMDB Series since metadata is complete and overwrite from IMDB is not required
INFORMATION> 2026-08-05T10:13:47 MCEBuddy.Transcode.ConvertWithHandbrake --> Setting up Output filename
INFORMATION> 2026-08-05T10:13:47 MCEBuddy.Transcode.ConvertWithHandbrake --> Replacing user specified parameters
INFORMATION> 2026-08-05T10:13:47 MCEBuddy.Transcode.ConvertWithHandbrake --> Converting the video - Main conversion
INFORMATION> 2026-08-05T10:24:43 MCEBuddy.Transcode.ConvertWithHandbrake --> Correcting Audio Delay if required
INFORMATION> 2026-08-05T10:24:43 MCEBuddy.Transcode.ConvertWithHandbrake --> Remuxing video if required
INFORMATION> 2026-08-05T10:24:43 MCEBuddy.Engine.ConversionJob --> Converted File : E:\Temp\working0\The Grinder (2015)-S01E01-Pilot-MP2-720x480-AC3-5.1.mkv
INFORMATION> 2026-08-05T10:24:43 MCEBuddy.Engine.ConversionJob --> Checking if commercials were found
INFORMATION> 2026-08-05T10:24:43 MCEBuddy.Engine.ConversionJob --> Commercials not found or cutting already completed
INFORMATION> 2026-08-05T10:24:46 MCEBuddy.Engine.ConversionJob --> Checking for Chapter information in Source File to preserve
ERROR> 2026-08-05T10:24:46 MCEBuddy.Engine.ConversionJob --> Unhanded error during conversion, conversion cancelled
System.NullReferenceException: Object reference not set to an instance of an object.
at MCEBuddy.CommercialScan.EDL.AdjustChaptersForEDLCuts(List`1 Chapters, List`1 cutList)
at MCEBuddy.Engine.ConversionJob.Convert()
INFORMATION> --> Total time taken by conversion (hh:mm:ss) -> 00:15:42
It also errors out (fails to convert) after some kind of error in the chapter processing.
Here is the Configuration for the procesing:
[MKV-LastResort-HD]
Profile=MKV AV1
DestinationPath=E:\Video
WorkingPath=E:\Temp
FallbackDestination=False
CheckReprocessingHistory=False
AddToiTunesLibrary=False
AddToWMPLibrary=False
AutoIncrementFilename=False
SkipReprocessing=True
MaxWidth=1920
FPS=
VolumeMultiplier=0.4
QualityMultiplier=0.6
RenameBySeries=True
AltRenameBySeries=False
CustomRenameBySeries=%ifseason%<\TV Shows\%showname%\Season %season%##\%showname%-S%season%##E%episode%##-%episodename%-%airyear%-%airmonth%-%airday%-%recordhour%%recordminute%,\Specials\%showname%-%subtitle%-%episodename%-%airyear%-%airmonth%-%airday%-%recordhour%%recordminute%>
RenameOnly=False
DownloadSeriesDetails=True
DownloadBanner=True
ForceFilenameMetadata=False
OverwriteMetadataInternet=Default
FileSelection=path:~*\MetadataRewrite\*
MetaSelection=
MetaChannelSelection=*;~*DT;~*DT2;~*DT3;~*DT4;~*DT5;~*DT6;
MonitorTaskNames=
DRC=True
AudioLanguage=
AudioOffset=0
InsertQueueTop=False
ExtractXML=False
WriteMetadata=True
AutoDeInterlace=False
PreferHardwareEncoding=True
StereoAudio=True
EncoderSelectBestAudioTrack=True
DisableCropping=False
StartTrim=0
EndTrim=0
ExtractCC=default
SaveSubtitles=False
CCOffset=2.5
EmbedSubtitles=True
EmbedChapters=True
StrictProcessing=False
ExtractAdsFromChapters=False
OCRBurnedInSubtitles=False
TaskCommercialSkipCut=False
KeepAdvertisements=False
MetadataMatchPriority=AirDate
SkipCopyBackup=False
SkipRemux=False
IgnoreCopyProtection=True
TiVOMAKKey=5183339978
Enabled=True
ForceShowType=Default
MetaShowTypeSelection=Series
MetaCodecSelection=Any
GpuSelection=NVidia
MetaDRMTypeSelection=All
FileSizeCompareType=LessThan
FileSizeThreshold=0
VideoBitrateCompareType=LessThan
VideoBitrateThreshold=0
VideoWidthCompareType=LessThan
VideoWidthThreshold=0
CommercialRemoval=Comskip
ComskipINI=
ComskipCLIParams=
