Subtitles have question marks in accented letters
Hello good evening,
I am using mcebuddy latest version 2.6 release 5. My subtitles that have accents (é ã etc.) are not working. When I use the configuration to extract embedded subtitles, or copy the .srt subtitles to the directory, or copy from the directory and insert them into the converted file. It does not work. It is in place of these letters putting a question mark ? and a dark triangle in the background. It only works if the subtitle is embedded and I check the embeded option, then the subtitle that has accents works! What can I do to fix this?
Can you attach your .srt file and conversion log
