I need to be able to cut segments smaller than you minimum. Is there a way I can adjust it when using custom cuts edl. Some of my segments are not being cut because segment size is to small.
The minimum segment size is about 25 seconds. Do you have an ad segment that’s less than 25 seconds?
yes, I’m cutting smaller segments from videos… I went back to an older version of MCEBuddy so I could continue doing that, but would like for your program to allow the user to adjust segment size so I can continue using the updated one.
What’s the smallest segment that you’re looking to cut?
5 or 6 seconds I suppose, I just thought it would be easier to give the end user the ability to set it. if not it’s not a problem, your older version works well for what I’m editing and I am willing to continue using it.
Added support to adjust the Minimum commercial segment size in today’s 2.4.9 BETA build in the Settings -> System Settings page
