MECBuddfy2\ 2.7.1 gets a code 2 error- and stiops.
026-03-12T19:38:00 MCEBuddy.AppWrapper.Comskip → Output folder for cutlist
2026-03-12T19:38:00 MCEBuddy.AppWrapper.Comskip → Detection Methods
2026-03-12T19:38:00 MCEBuddy.AppWrapper.Comskip → 1 - Black Frame
2026-03-12T19:38:00 MCEBuddy.AppWrapper.Comskip → 2 - Logo
2026-03-12T19:38:00 MCEBuddy.AppWrapper.Comskip → 4 - Scene Change
2026-03-12T19:38:00 MCEBuddy.AppWrapper.Comskip → 8 - Resolution Change
2026-03-12T19:38:00 MCEBuddy.AppWrapper.Comskip → 16 - Closed Captions
2026-03-12T19:38:00 MCEBuddy.AppWrapper.Comskip → 32 - Aspect Ratio
2026-03-12T19:38:00 MCEBuddy.AppWrapper.Comskip → 64 - Silence
2026-03-12T19:38:00 MCEBuddy.AppWrapper.Comskip → 128 - CutScenes
2026-03-12T19:38:00 MCEBuddy.AppWrapper.Comskip → 255 - USE ALL AVAILABLE
2026-03-12T19:38:00 MCEBuddy.AppWrapper.Comskip → Comskip 0.83.001-20250228, made using ffmpeg
2026-03-12T19:38:00 MCEBuddy.AppWrapper.Comskip → Donator build
→ Process exited with code 2
WARNING> 2026-03-12T19:38:02 MCEBuddy.AppWrapper.Comskip → Comskip failed
INFORMATION> → Comskip version : DONATOR
INFORMATION> → Comskip build : CUSTOM
AI, which is never wrong (hahaha), says that Version 2.7.1 is not compatiable with the Comskip DONATOR version.
Comskip started normally
It loaded detection engines and your INI file.
Comskip printed its version
This means the executable is running.
Comskip immediately exited with code 2
This is the smoking gun.
Code 2 = invalid command‑line argument
This is documented behavior.
It means MCEBuddy passed a flag that your Comskip build does not support.
This happens before Comskip even begins analyzing the video
So the video file is not the issue.
Root Cause (confirmed)
Comskip Donator 0.83.001 is too new for MCEBuddy 2.7.1.
Comskip 0.83.x changed its command‑line parser and removed/renamed some flags.
So Comskip sees an unknown flag → exit code 2 → MCEBuddy reports failure.
This is the exact failure other users reported with 0.83.x Donator builds.
What adise can you give me.
Thanks
Chris
