Processing .mp4 proceeds to finish with “MCEBuddy has crashed” MCEBuddy service continues to run.
Logs please (attach mcebuddy.log)
Also click on the Events link on the GUI and see what it shows.
Logs have been downloaded to ftp location dbullendsl
You have a bad install
ERROR> 2024-02-28T11:57:03 MCEBuddy.Engine.Core --> MCEBuddy Monitor Thread Crashed. Error: System.IO.FileNotFoundException: Could not load file or assembly 'ObjectDumping, Version=1.0.0.0, Culture=neutral, PublicKeyToken=5b84c0cf1ad6e363' or one of its dependencies. The system cannot find the file specified.
File name: 'ObjectDumping, Version=1.0.0.0, Culture=neutral, PublicKeyToken=5b84c0cf1ad6e363'
at MCEBuddy.Engine.Core.WriteJobHistory(ConversionJob job)
at MCEBuddy.Engine.Core.MonitorEngineThread()
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
This happens if you try to upgrade from a version prior to 2.6.3 directly without first uninstalling the old version: MCEBuddy Monitor Thread Crashed after first item is processed in the queue v2.6.2 - #4 by Goose
Uninstall and reinstall MCEBuddy and it should be fine.
Yep, that fixed it ,
Thanks
