After restarting service, the queue is loaded. Once the first queued item is finished system crashes. Will not process the remaining queue until services is stopped and restarted.
mcebuddy.log (2.2 MB)
Error 13-Jan-2024 9:02 AM
MCEBuddy Monitor Thread Crashed. Error: System.IO.FileNotFoundException: Could not load file or assembly ‘ObjectDumping, Version=1.0.0.0, Culture=neutral, PublicKeyToken=5b84c0cf1ad6e363’ or one of its dependencies. The system cannot find the file specified.
File name: ‘ObjectDumping, Version=1.0.0.0, Culture=neutral, PublicKeyToken=5b84c0cf1ad6e363’
at MCEBuddy.Engine.Core.WriteJobHistory(ConversionJob job)
at MCEBuddy.Engine.Core.MonitorEngineThread()
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
NOTE: Don’t forget to attach your conversion log or MCEBuddy.log file as appropriate
