FuConversion Log: https://pastebin.com/nfnqThKv.
I see previous posts about thetvdb.com not being available. I just tested from the machine and am able to access the site. Please advise
Nothing to do with the metadata, that’s working just fine.
Your remux is failing
INFORMATION> 2019-05-07T19:56:18 MCEBuddy.RemuxMediaCenter.RemuxMCERecording → Fast Remuxing
2019-05-07T19:56:18 MCEBuddy.RemuxMediaCenter.RemuxMCERecording → Reading MediaInfo from \synology\HDHomeRunDvr\Jeopardy!\Jeopardy! S35E172 20190507 [20190507-2300].mpg
2019-05-07T19:56:19 MCEBuddy.RemuxMediaCenter.RemuxMCERecording → Video FPS : 59.94
INFORMATION> 2019-05-07T19:56:19 MCEBuddy.RemuxMediaCenter.RemuxMCERecording → Copy remux loop 0
ERROR> 2019-05-07T19:56:19 MCEBuddy.RemuxMediaCenter.RemuxMCERecording → ReMuxer failed to create remux file
INFORMATION> 2019-05-07T19:56:19 MCEBuddy.RemuxMediaCenter.RemuxMCERecording → Slow remux loop 0
ERROR> → Slow Remux using FFMPEG failed at 100%
WARNING> 2019-05-07T19:56:19 MCEBuddy.RemuxMediaCenter.RemuxMCERecording → Unable to copy remux using FFMPEG, trying other methods
Either MCEBuddy can’t access your source file or your mcebuddy.conf file is corrupted and the remux settings section is missing/corrupted. You can attach your mcebuddy.conf file or try a fresh install to restore it.
i made zero changes and everything is working now. thaanaks for the reply
