MCEBuddy 2.4.7 32bit
Windows 7 Professional 32-bit
I had been using the MCEBuddy 2.4.7 32bit - 20170627 beta release with a profile that uses custom commands. Since upgrading to the release of 2.4.7, those commands no longer properly quote the arguments passed to the custom commands. From my profiles.conf:
In the 20170627 release, the parameters would come through with the quotes (e.g., TvRecordingMover.exe source=“D:\Output\Some File.mkv” orig=“D:\DVR\Some File.mkv” delete=true). After updating, the parameters no longer have quotes (e.g., TvRecordingMover.exe source=D:\Output\SomeFile.mkv orig=D:\DVR\SomeFile.mkv delete=true), which causing parsing errors with files that contain spaces (which is all of them). Did something change? Thanks.
Of course, when I reverted back to the last working version for me, my old conversion logs were removed. I’ll have to recreate with the release version during some downtime.
Each program processes the inputs parameters and quotes in a different way, some can’t handle total wrapping of quotes while others can’t handle nested quotes.
For example, when using command line, windows always connects the quotes in pairs and breaks the parameters at the next next space, so when you’re using the following command line parameters:
