Bar Rescue Refuses To Process
NOTE: Don’t forget to attach your logs & samples as appropriate
everything but Bar Rescue processes fine. i even made a new profile for it.
Sure glad i paid for another year, your customer service is fantastic. NOT! These forums are a waste of hard drive space and bandwidth if you don’t help out with the product that CHARGE people for with support.
I don’t see any logs attached
Because it’s not doing ANYTHING.
I thought I mentioned the fact that it refuses to process any of Bar Rescue.
Is there a mcebuddy.log file in the log directory? That will have the scan information on any potential reason why files aren’t getting picked up.
Open it up and search for one of the file names of the Bar Rescue files and see if can help troubleshoot the issue you are experiencing. Or you can attach it and we can take a look.
There is nothing. Not a single log, I have cleared history and installed the newest version.
Even cleared the logs folder.
Like they are ghost files, not appearing anywhere in MCEBuddy.
The only thing I haven’t tried is renaming it, but that wouldn’t be sustainable.
That’s strange, there should at least be an mcebuddy.log. It should log that it scanned the monitor location where your files are located.
That’s what I would figure. I’m at a loss on this one.
Could you attach your mcebuddy.conf from the config folder. Feel free to make a copy and remove any personal details you don’t want to share (email address, usernames, etc). And then provide a location and filename example of a file that won’t process and one that does process.
Sorry about the raw paste
[Process and Move]
SearchPath=E:\Unprocessed TV
SearchPattern=*.ts
SearchPathExclude=
DeleteMonitorOriginal=True
ArchiveMonitorOriginal=False
ArchiveMonitorPath=
MonitorSubdirectories=True
MonitorConvertedFiles=False
ReMonitorRecordedFiles=False
MinimumAge=1
DomainName=
UserName=
ArchiveDomainName=
ArchiveUserName=
[Convert to MP4 and Move]
Profile=MP4 Unprocessed with Plex Analyze Direct 2a
DestinationPath=
WorkingPath=
FallbackDestination=False
CheckReprocessingHistory=False
AddToiTunesLibrary=False
AddToWMPLibrary=False
AutoIncrementFilename=False
SkipReprocessing=False
MaxWidth=1920
FPS=
VolumeMultiplier=0
QualityMultiplier=1
RenameBySeries=False
AltRenameBySeries=False
CustomRenameBySeries=
RenameOnly=False
DownloadSeriesDetails=True
DownloadBanner=True
ForceFilenameMetadata=False
OverwriteMetadataInternet=Default
FileSelection=
MetaSelection=
MetaChannelSelection=
MonitorTaskNames=Manual/CLI files,Process and Move,Unprocessed
DRC=False
AudioLanguage=
AudioOffset=0
InsertQueueTop=False
ExtractXML=False
WriteMetadata=True
AutoDeInterlace=True
PreferHardwareEncoding=True
StereoAudio=True
EncoderSelectBestAudioTrack=True
DisableCropping=True
StartTrim=0
EndTrim=0
ExtractCC=
CCOffset=0
EmbedSubtitles=False
EmbedChapters=True
StrictProcessing=False
ExtractAdsFromChapters=False
TaskCommercialSkipCut=True
KeepAdvertisements=False
PrioritizeOriginalBroadcastDateMatch=False
SkipCopyBackup=True
SkipRemux=False
IgnoreCopyProtection=False
TiVOMAKKey=
Enabled=True
ForceShowType=Default
MetaShowTypeSelection=Default
MetaCodecSelection=Any
GpuSelection=Any
MetaDRMTypeSelection=All
FileSizeCompareType=GreaterThan
FileSizeThreshold=400
VideoBitrateCompareType=LessThan
VideoBitrateThreshold=0
VideoWidthCompareType=LessThan
VideoWidthThreshold=0
CommercialRemoval=Comskip
ComskipINI=
DomainName=
UserName=
MetaCorrectionsCount=0
[MP4 Unprocessed with Plex Analyze Direct 2a]
Description=This profile runs post custom commands but usues MP4 Unprocessed
order=ffmpeg
ffmpeg-general=-threads 0
ffmpeg-video=-ss 0 -vcodec copy -sn
ffmpeg-audio=-acodec copy
ffmpeg-audioac3=-acodec copy
ffmpeg-ext=.mp4
ffmpeg-audiodelay=skip
FixedResolution=true
SkipCropping=true
AutoDeinterlace=false
PostCustomCommandPath=D:\ForceAnalyze.bat
PostCustomCommandParameters=%showname%
PostCustomCommandHangPeriod=700
PostCustomCommandCritical=true
PostCustomCommandUISession=true
PostCustomCommandShowWindow=false
PreMetaCustomCommandExitCodeCheck=true
I’ll also add, this is the only show that refuses to process. Everything else is fine.
Can you give an example of a full path to a file that isn’t getting processed?
“E:\Unprocessed TV\Bar Rescue\Season 8\Bar Rescue S08E22 Till Failure Do You Part.ts”
What is the file size?
That was 20secs long, not valid for that filter…
Here is a different one that didn’t process:
“E:\Unprocessed TV\Bar Rescue (2011)\Season 6\Bar Rescue S06E18 Fish Out of Blue Water.ts”
Screenshot_20240817-101941
It’s currently set that it has to be greater than 400 mb so this one with size of 359 mb would not be processed. Try decreasing the file size filter to maybe 300 mb or 350 mb and see if you have better luck.
@Tony_B, did this resolve your issue?
I don’t know how I missed that. I am encoding files differently and that is a hell of a small file for 1hr.
Thanks for uncovering that.
No problem, easy to miss an under 400 mb for 1 hour show normally seems unlikely. Glad it’s resolved.
