After my videos have had ads removed the sync is lost. Anyway, I can fix this. I ran through over 100 videos that didn’t work right.
When you say “the sync is lost”, do you mean it is as if the video for the ad was cut, but the audio for the ad was retained? Or does the audio clip differently than the video (before or after)?
It may be a problem where the original audio track was processed separately and has a different playback rate than the video, and then they were combined. Are these 100+ videos all from the same source or processing before you ran it through MCE Buddy?
It might be a problem where MCE Buddy isn’t cutting on i-frames (sync points in the media), which I think was fixed in a recent version. Are you using the current version (202506020)?
When an ad hits, the sound and video don’t stay in sync. They are about 3 - 5 seconds apart. Audio is always behind the video. I was on 2.6.4 but have since upgraded to 2.6.5.
You can adjust the audio sync in many different ways, see this link to get started to see if that resolves your issue
