I only seem to notice lengthy conversions for Jeopardy!, is there somethings that makes the entire task take so much longer than other 30 minute shows?
Your conversion is taking just a few seconds. The metadata look up on the internet is taking 17 minutes. Could be a bad internet connection, website or maybe that you’re not running the latest version. Try the latest 2.5.3 BETA
<Start At Date/Time> <Duration (hh:mm:ss)> <Activity>
--> <01/31/2020 16:21:38> <00:00:00> <Running custom commands>
--> <01/31/2020 16:21:38> <00:17:31> <Getting show information and banner from Internet sources>
--> <01/31/2020 16:39:10> <00:00:00> <Running custom commands>
--> <01/31/2020 16:39:10> <00:00:05> <Checking for disk space>
--> <01/31/2020 16:39:15> <00:00:19> <Remuxing recording>
--> <01/31/2020 16:39:34> <00:00:00> <Trimming video recording>
--> <01/31/2020 16:39:34> <00:00:11> <Analyzing video information>
--> <01/31/2020 16:39:46> <00:00:00> <Extracting closed captions>
--> <01/31/2020 16:39:46> <00:00:06> <Extracting closed captions>
--> <01/31/2020 16:39:53> <00:00:00> <Validating closed captions>
--> <01/31/2020 16:39:53> <00:00:00> <Running custom commands>
--> <01/31/2020 16:39:53> <00:00:19> <Analyzing video information>
--> <01/31/2020 16:40:12> <00:00:07> <Converting>
--> <01/31/2020 16:40:19> <00:00:02> <Writing show information>
--> <01/31/2020 16:40:22> <00:00:00> <Renaming file using show information>
--> <01/31/2020 16:40:22> <00:00:00> <Running custom commands>
--> <01/31/2020 16:40:22> <00:00:00> <Moving converted file to destination>
--> <01/31/2020 16:40:22> <00:00:00> <Success - All done!>
INFORMATION> --> Total time taken by conversion (hh:mm:ss) -> 00:18:44
I have noticed exactly the same thing only with Jeopardy!. I am running 2.5.3 Beta. I don’t think it is MCEBuddy. I was going to try to have it not check for the metadata on Jeopardy to see if that helps as I don’t need that info.
MCE Buddy setting. I have a specific conversion task for Jeopardy, and under the Advanced Settings, Expert Setting I have unchecked Download Information and Add Information. Cuts off 17-25 minutes from my conversion. This information isn’t important to me as I just watch the show and then delete it.
