Premium version available through the Premium Access Program
Trial version is available here
Changelog for 2.5.4 (64bit)
ENHANCEMENTS:
- Use show images from HDHR Silicon Dust files as a backup if not available on the internet
- Detect local IP/hostnames for engine names and highlight if reconnecting to a remote engine
BUG FIXES:
- Fix subtitle naming convention to match Plex/Serviio
- Fix Fallback to source option in conversion task destination folder network credentials page cannot be enabled
- Detect if QSV decoding failures causes a partially converted file for older Intel chipsets
- Use primary Nvidia GPU card when multiple NVidia GPU cards are present
- Handle manually added files who’s paths are too long gracefully
