Comskip seems to have stopped working when transcoding my Plex recordings.
The weird thing is if I take the MKV MCEBuddy creates, run it against a MKV unprocessed profile with Comskip enabled, it will pull out the commercials from it.
You’re using a custom INI file and MCEBuddy can’t find the EDL file generated by comskip after it completes. Check that your ini file isn’t changing the default output location of the EDL file or possibly its locked by some other program.
MCEBuddy.AppWrapper.Comskip --> Using C:\Users\wct\Comskip\comskip.ini for initiation values.
2020-04-03T17:33:56 MCEBuddy.AppWrapper.Comskip --> Commercials were found.
–> Process exited with code 1
2020-04-03T17:33:58 MCEBuddy.CommercialScan.Scanner --> Commercial Scan: Percentage Complete 99
INFORMATION> 2020-04-03T17:33:58 MCEBuddy.CommercialScan.Scanner --> Skipping EDLP, using EDL file for commercial removal
WARNING> 2020-04-03T17:33:58 MCEBuddy.CommercialScan.Scanner --> Cannot find or access EDL File
