IS there a way I can shorten the channels name, removing the end information. For Ex.
1500 Steps (2014) 2020-07-02-1229 renamed to
1500 Steps (2014)?
Thanks
1500 Steps (2014)?
Thanks
Yep.
When you select the conversion task, choose advanced settings and then choose the “enable custom renaming” - and fill out the code in the text box below. The tooltips contain the format for the code - it’s pretty simple to manipulate.
