Rename other than %showname%, %filename% perhaps
I don’t see a simple %filename% as a rename method. How would I rename the original filename, after comskip processing, with a simple -CS for comskip appended to the end of the filename? If used it picks up the %showname% from presumably the .nfo file but doesn’t pick up %airmonth% even though this info is in the .nfo contents shown below as . My source file naming convention is showname-hour-date. Would like it to be showname-hour-date-CS after processing. What am I missing?
Desperate Hours-Earthquake-20190703-2230.txt (459 Bytes)
%originalfilename% - Name of the source file (without the path or extension)
You would use %originalfilename%-CS
Excellent, thanks for this!
