I just started using MCEBuddy, and I use NextPVR for my recordings. It already has them organized by TV show and season. Is there a way to just mirror that folder structure in the output from MCE buddy? Basically, I would like the output files to be sorted in folders by show and season. Thanks.
Do you want the files back in their original folders (leave the destination folder blank) or if you want to replicate the original folder structure you can use the custom renaming option (%originalfilename%)(refer to the Topic on Advanced Commands) to recreate it.
Also try the Organize shows by Seasons renaming option if that works for you or The other stock renaming patterns.
